Sprint Heater stub pipes http://forum.triumphdolomite.co.uk/viewtopic.php?f=4&t=36521 |
Page 1 of 1 |
Author: | Carledo [Sat Feb 20, 2021 7:50 pm ] |
Post subject: | Re: Sprint Heater stub pipes |
They are normally soldered in place. The pipes come in one piece with the tap incorporated as part of the heater rad itself. You may well need to remove the box and separate the rad out from it to repair the damage properly. I've known it to be tough to remove the heater hoses when they've been on a long time, but i've never bust a pipe off. Nowadays, if i'm changing the hoses, I undo the clip and slide it up the hose then slit the hose with a Stanley blade to get it to peel off easier and probably forestall this dilemma. If you can't fix it or the pipe is broken rather than just pulled out, I can offer you a heater box with watertight rad and functional tap for sensible money. I even have 1 NOS one. (though that would be dearer) Steve |
Page 1 of 1 | All times are UTC |
