Dolomite 1300 starter solenoid :Earthing.
http://forum.triumphdolomite.co.uk/viewtopic.php?t=36656
Author:  MIG Wielder [ Sat Apr 24, 2021 12:35 pm ]
Post subject:  Dolomite 1300 starter solenoid :Earthing.
The Dolomite 1300 starter solenoid reminds me of my early Mini ! The question is ... there are 4 terminals. 2 for the high currents in and out, 1 x red/ white for Ignition ballast and a yellow/ white for the ignition key switch.
So when you turn the key to the Start position, 12V will be applied to the white/yellow wire to operate the solenoid. But where is the return path to earth ? Is it through the fixing bolts, meaning you have to keep those clean, or is it like the Sprint / 1850 with the earth connection being made through the low resistance starter motor winding ?
Thank you,
Author:  Magenta Auto Sprint [ Sat Apr 24, 2021 1:13 pm ]
Post subject:  Re: Dolomite 1300 starter solenoid :Earthing.
yes it earths through the mounting flange, just tested mine on the bench.
Malcolm
Author:  MIG Wielder [ Sat Apr 24, 2021 5:29 pm ]
Hi Malcolm, Thanks very much for confirming that; It is just as we thought.
Cheers for now,
Author:  Larry 1300 [ Mon May 03, 2021 3:34 pm ]
Thank you,
Hi could anyone tell me what size the screws are that mount the solenoid to the wing please. So that I can order new ones. Thanks
Author:  MIG Wielder [ Mon May 03, 2021 5:30 pm ]
Hi Lawrence, The parts book, page 1N 04L, shows the bolts as part no; 513249 with washers WM55. I had a look for these on the www. and drew a blank. So there must be something unusual about them, Like length ? If they go into captive nuts then they will probably be UNF / BSF , If not they will probably be self-tappers.
HTH,
Author:  Larry 1300 [ Tue May 04, 2021 8:29 am ]
Hi thanks for that. I found reference to the page that you mentioned on the internet but got no further than that. Anthony said that they may be self tappers. Laurence 👍
Author:  Carledo [ Tue May 04, 2021 11:00 am ]
The parts list pic definitely shows what appears to be parallel thread rather than a tapper and the index, unhelpfully, just calls it a screw. My hazy memory from my Toledo, which shared the remote solenoid before I ripped it all out to fit a Vauxhall motor in 2008, is of setscrews in captive nuts in the flitch, but not the common or garden 1/4" UNF that secure most bits in that area, more like a 3/16" UNF or possibly a BA.
Thinking about it, though the solenoid is long gone, the flitch (and holes) are still there! I'll have a look when the rain eases up!
Author:  Magenta Auto Sprint [ Tue May 04, 2021 12:36 pm ]
they may be 10/32 unf or something like that.
malcolm
Author:  Carledo [ Tue May 04, 2021 12:38 pm ]
OK, i've investigated and it's definitely a captive nut fitting and smaller than 1/4" Whatever it is, it's the same thread as the screws that held the coil in place, just above it on the strut tower. I've searched through my screw collection, garnered from many scrapped Dolomites and easily found a couple of short-ish, new-ish Phillips head setscrews that fit nicely, if somebody wants them!
Author:  captain_70s [ Tue May 04, 2021 4:20 pm ]
I did indeed think they were self tappers, but on removal they are a fine thread of some description!
Author:  Magenta Auto Sprint [ Wed May 05, 2021 12:24 pm ]
A quick summary to small thread sizes:-
U.N.F = Unified National Fine
T.P.I = Threads Per Inch
B.A = British Association
1/4 U.N.F 28 T.P.I Major Diameter 0.250
O B.A 25.4 T.P.I Major diameter 0.236
12/28 U.N.F 28 T.P.I Major Diameter 0.216
10/32 U.N.F 32 T.P.I Major Diameter 0.190
All these screws sizes are available on the internet from various suppliers in stainless steel if required.
Malcolm
Author:  Carledo [ Wed May 05, 2021 2:40 pm ]
Malcolm
The last 2 of these make no sense Malcolm, 10/32" is better known as 5/16", the common or garden (and misnamed) "half inch bolt", half an inch being the head size across flats. The major diameter of this bolt should be 0.3125", TPI around 24 iirc
The other one makes even less sense, 12/28" translates down to 6/14 and NOBODY measures ANYTHING in fourteenths of an inch!
The screws I have found have a major diameter around 5/32-3/16" ( 0.15625-0.1875", I dont have a vernier caliper to be more precise) and a TPI count of 28-30, the screws are 1/2" long and I get a thread count of 14 or 15 depending on where in the circumference of the screw I count it.
Author:  Magenta Auto Sprint [ Wed May 05, 2021 10:37 pm ]
Steve,
Perhaps this will explain this better. I think you mean 3/16 and not 5/16th?
https://journeymans-workshop.uk/unified.php
Malcolm
Author:  Carledo [ Wed May 05, 2021 11:17 pm ]
Steve,
Malcolm
Ah that explains it! 10/32 is not a measurement! My schoolboy fractions, using lowest common denominator, translated 10/32 as 5/16, when in fact it's a NUMBER 10 screw with 32tpi. This also accounts for 12/28.
This makes the screws I have most likely No10 UNF.
Author:  Larry 1300 [ Wed Jun 08, 2022 8:25 pm ]
Hi you were spot on with the size of the bolts. Size 10. Thanks
Page 1 of 1 All times are UTC+01:00
https://www.phpbb.com/
