It is currently Sun May 16, 2021 9:06 pm
Post new topic Reply to topic  [5 posts ]
PostPosted:Wed Apr 28, 2021 5:54 pm
TDC Lincs Area Organiser
Hi all
I want to remove the driveshaft flange nut on my gearbox (Sprint), how do other people do this? Officially it requires an RG421 tool but I guess these no longer exist, do most people fabricate something instead? I tried securing two bolts on to the gearbox flange and locking with a crowbar and attempting to undo the bolt with a socket and extension bar but I stopped as it didn't feel overly safe! Thanks for any advice :-D
PostPosted:Wed Apr 28, 2021 7:33 pm
Online
Put it in gear and use a rattle gun, that's my preferred method!
'72 Triumph 1500FWD in Slate Grey
 Post subject: Hmmm.......
PostPosted:Wed Apr 28, 2021 8:22 pm
:D Not possessing a rattle gun or any type of gun for that matter,
I bolt a length of channel to the flange (as this is safer than the prybar wedged in place option)
Ian
PostPosted:Wed Apr 28, 2021 8:51 pm
Thanks to you both, looking at the leaking diff seal I will need to do the same there too! :roll:
PostPosted:Wed Apr 28, 2021 11:28 pm
I got a piece of 40x5 flat bar. Drilled two holes and notched out a bit to allow the socket to pass. If the axle is still in situ then let the bar rest against the floor.
2007 Porsche Boxster S
You can't start a sentence with 'And'.
Grammar:
Schedule: Pronounced "Shedule" not "Skedule"!
Display posts from previous: Sort by
Users browsing this forum: AhrefsBot [Bot], MegaIndex [Bot], SEMrush [Bot] and 1 guest
