It is currently Thu Apr 25, 2024 5:14 pm
 Post subject: Blue clock
PostPosted: Fri May 07, 2021 8:15 pm
I've collected a clock that fits in the Doly dash, and so the Mk1 Stag, at least some of the 2000/2500 models, and I understand some of the Jensen Interceptors. All of which, it seems, light up green
However, this one lights up blue, like the Rover a Ford ones. But they have a different mounting: a raised lug behind 12 o'clock and a screw in the tube they fit in, not the 3 spring clips on the ones for the Triumph.
So, does anybody know of a car with a clock that fits with the 3 clips and plastic ring like the Dolomite, but lights up blue?
 Post subject: Re: Blue clock
PostPosted: Sat May 08, 2021 9:10 pm
isn't it just the plastic filter in the bulb holder, they are easy to change?
PostPosted: Sun May 09, 2021 4:04 pm
You are quite right, it is the plastic light guide that set the colour on this model, and later ones - it was paint on the inside of the case before that. Some of the later ones, where the hands come off easily, you can easily swap the plastic - though I'm already short a good green one. But the ones like this one, it's not at all easy.
This is one where the front adjuster act directly on the minute hand, which has a silver centre. So that's fixed securely to the minute drive shaft so it turns the hour hand when you adjust - there's a clutch between the clockwork and the minute shaft to allow that. I expect the hands do come off somehow, and I have another with the same hands where the clutch has gone I think, or the min shaft is too tight for the clutch to drive it. So I can look at how the hands come off as I try to fix that.
Also the front bezel on this 3-clip blue one had definitely not been off before I removed it - I did that cos someone had broken the 3 clips off to hammer it into a Cortina 1600E and it needed the Kienzle guarantee expiry device fixing (they call it a fusible link).
So, all in all, I reckon it was made with the 3 clips and a blue plastic insert. And so, maybe a bit rarer than the green ones, even if I could make one from one each of the right triumph and rover/ford clocks.
I've since seen another like it on eBay from a firm that seem to deal mostly in Roller bits, but I can't see any pics of Rollers with a Kienzle quite the same as this.
PostPosted: Sun May 09, 2021 5:52 pm
I've had a right good go at getting the hands off the mechanism the same as this blue one, and I reckon they are welded on or pressed with that much force I'll damage something if I pull harder.
So, If I was to put a green lighting one in this case, cos at least it would fit a Doly/Stag/Interceptor and so I could sell it. I'd have to swap the whole mechanism from another clock.
Users browsing this forum: No registered users and 16 guests
