[1300 TC FWD] Weird front rubber configuration http://forum.triumphdolomite.co.uk/viewtopic.php?t=36753 |
Page 2 of 2 |
Author: | trubac [ Mon Jun 21, 2021 11:41 am ] |
Post subject: | Re: [1300 TC FWD] Weird front rubber configuration |
Quote: Export arrangement from Belgium? I have a French imported 1300 what was build in Belgium and a Dutch 1300tc made in Belgium. These don't differ from eachother except early and late, carbs etc. but these dont differ from the UK spec other than mine have the steering wheel fitted on the correct side. Also enginemounts the same as the UK spec and the same through the whole range. Jeroen |
Author: | trubac [ Mon Jun 28, 2021 9:20 am ] |
sorry it the camera angle, its 50 from bottom of plate to top of bolt and 35 to top of rubber.
Finally measured mine (T2000) and in situ it is approx 35mm thick ... compressed. I will ask a T2000 guy to measure it unloaded.
Page 2 of 2 | All times are UTC |
