Aerial fix http://forum.triumphdolomite.co.uk/viewtopic.php?t=36759 |
Page 1 of 1 |
Author: | john whitehead [ Thu Jun 24, 2021 12:14 pm ] |
Post subject: | Aerial fix |
Newish member just got Sprint back from restorers. Can't see access to fit new period aerial to hole on front o/s wing. Is there a 'topic' on this I can follow to solve problem ? Thanks |
Author: | Carledo [ Thu Jun 24, 2021 8:56 pm ] |
Post subject: | Re: Aerial fix |
There is a shield plate in the back of the wheel arch (metal on earlier cars, plastic from around 75>) that has to be removed to access the ariel and also the hole in the kick panel the cable passes into the car through. It's secured by 3 x 1/4" unf bolts, easiest to take the wheel off first. Steve |
Page 1 of 1 | All times are UTC |
