It is currently Wed Apr 24, 2024 4:16 am
PostPosted: Wed Jul 07, 2021 6:58 pm
The Waxstat HS4s on my SE are causing me endless issues: rarely in balance, generally lumpy and frustrating.
It's been a long time since I last swapped around engines in our cars: can anyone confirm for me that the single SU and matching manifold are a direct swap with my twins? I know it'd make marginally less power/torque, but none of my Toledos have ever given me fueling issues, so am looking for a fit and forget solution.
Thanks.
PostPosted: Wed Jul 07, 2021 7:04 pm
Thanks.
The dolly 1300 inlet will not fit with the twin outlet exhaust manifold. I tried. Really tried. But no....
(and when tested back in the 90s, there is naff all difference, maybe 2-3bhp in a proper trial)
Have you tried the 2p waxstat removal? simple and often cures many ills.
PostPosted: Wed Jul 07, 2021 7:28 pm
Thanks, Clive.
Could you remind me about the 2p thing? Rings a bell but can't recall the details. Thanks.
PostPosted: Wed Jul 07, 2021 11:39 pm
Odds are the problem you are blaming on the twin carb setup is really down to worn components on the carbs or an airleak from something like a split breather hose.
One thing I would suggest, if you don't already have one, is buying an airflow meter. It makes balancing carbs far easier and will be more accurate than doing it by ear.
PostPosted: Fri Jul 09, 2021 9:20 am
or use the SU waxsat conversion kit which I used on mine,
http://sucarb.co.uk/waxstat-jet-conversion.html
Malcolm
PostPosted: Fri Jul 09, 2021 9:27 am
Site Admin
Site Admin
Malcolm
I second that :thumbsup:
PostPosted: Fri Jul 09, 2021 12:50 pm
Thanks, all, much appreciated. I'll give the conversion kit a whirl along with a comprehensive service.
Users browsing this forum: DotBot [Bot], Google and 57 guests
