Mild head porting + port matching inlet/exhaust.
"Accidentally" stick a TR7 engine in for a few more CC?
Not aware of any off-the-shelf cam upgrades for an 1850 at the moment - I wish somebody like Newman cams did one.
I am bit cynical about the benefits of porting. Gas flow is incredibly complex and difficult to model. I find it unlikely that someone working at home with a dremel is going to succeed. In fact I would put good money on them making things worse.
It is certainly more complex than simply making the ports bigger and knocking off sharp edges.
Perfection is almost certainly beyond a man with a dremel and needs at least a flowbench.
But port matching doesn't and gives proven results. Yes, it's easy to go just that little bit extra - and go too far. But if you're sensible, there are gains to be made for very little cash outlay.
Easier on older engines as they were much rougher to start with, modern stuff is made with tighter tolerances because higher efficiency is demanded. That's why a 70s production 2 litre 16v (Sprint) makes 127 bhp and a 2020 production 2 litre 16v makes 250bhp or more. It's still an internal combustion engine with the same basic design, just built better! Nowadays Ford will sell you a 1 litre 3 cylinder car that puts out over 140bhp, I wouldn't buy one as that sort of output can't last long IMO, but what do I know?
