It is currently Wed Apr 24, 2024 7:26 am
PostPosted: Thu Nov 18, 2021 7:12 pm
On my newly acquired 1500TC 1974; I'm looking to try to turn the engine over by hand before I try to start it after being sitting for so many years, however when I went to attempt this I discovered the Crankshaft nut is far larger than expected and I haven't got a socket large enough :?
The manual states its 1"x16 T.P.I size? This has totally confused me as I don't recognise this measurement or size!
Does anybody know what size socket I need for this nut please?
On a separate note what is the best method of removing the nut without an impact wrench? I've seen a post about using the starter motor and a bar against the chassis to free the nut, has anyone done this and any recommendations of how to attempt this?
thanks
PostPosted: Thu Nov 18, 2021 7:34 pm
The socket is 1.13/16" which, IIRC is something like 43mm.
Not as hard to find/borrow as you might expect since it also fits Metro balljoints, your local classic friendly garage will probably have one!
And yes, it's reasonably simple to fit a socket to a long knuckle bar, rest said bar against the subframe and hit the starter switch. I've been releasing crank dog nuts by this method for over 50 years, not just on Triumphs, but everything else as well.
PostPosted: Thu Nov 18, 2021 9:00 pm
this is the actual thread size one inch diameter with a 16 threads per inch, although that doesn't fit with BSW, UNF, BSF or UNC thread forms.
Malcolm
PostPosted: Fri Nov 19, 2021 10:48 am
I think it’s a unified fine 16-UN thread.
Not very common, but 16tpi also used on lathes and other machine tools.
IFRC land rover track rods are 11/16 at 16tpi.
Peter.
1978 Dolomite Sprint - Inca
PostPosted: Fri Nov 19, 2021 10:59 am
I've got one that I cut down to fit on the end of a gun for a scrap engine whilst still in chassis. Works either way though with 3/4 to 1/2" adapter. As I don't have the car anymore, I'm happy to post it to you.
PostPosted: Sat Nov 20, 2021 2:11 pm
Same here.
Although not everything you haven't....
You won't have done it on a (or possibly a lot of) Honda(s).......
Care to take a guess as to why?
PostPosted: Sat Nov 20, 2021 3:17 pm
Same here.
'cos you'd be tightening it!
PostPosted: Sat Nov 20, 2021 3:37 pm
Same here.
Because the Honda crank (or at least, some of them) turns anticlockwise! Because of this the dognut does itself up even tighter in service. Quite often, even an industrial grade 1" drive airgun fails to loosen Honda dog nuts. My normal method involves removing the starter, locking the crank with a crowbar in the ring gear teeth and then loosening the dognut with a socket, long extension resting on an axle stand, turned by a 6ft long commercial torque wrench! Which I often end up literally swinging from!
I've also come unstuck once doing it like that on a newish Fiesta with no keyway on the crank pulley! A lot of moderns have this REALLY USELESS design now. Honestly, to save a few pence on machining costs and a Woodruff key!
But it's no bother on a PROPER car!
I WAS going to add these caveats on the initial post, but thought no-one would be interested in Hondas or other modern stuff!
PostPosted: Sat Nov 20, 2021 3:47 pm
I didn't think that I would catch you out with that one. I've been there doing all the above.
Which is why I don't do moderns.
There's always one....... :lol: :lol: :lol:
PostPosted: Sat Nov 20, 2021 3:50 pm
Same here.
Yep, and a proper PITA they can be.
Users browsing this forum: Bing and 53 guests
