The subject of the bypass tube has been comprehensively covered recently in the "Project PFJ is baaack!" thread in the resto section.
Turns out that pre 74, the tube can only be removed by taking the manifold off, after that it could be removed upward through the stat housing as shown in the manual. There was also an early tube design that, like the factory plug tubes, was rubber sheathed steel and therefore "one time use only". This tube is NLA and the modern ones with separate O rings are the norm.
I'm normally reluctant to remove the manifold if I don't HAVE to (it's a pig to seal the water gallery as has been said) and have used various methods to pull the tube out, most successful has been an old thread tap that just about grips inside the tube, pulled up with a mole grip.
But in your case I highly suspect that the manifold gasket is leaking around the water gallery which is directly above the pump housing and a leak here can often be mistaken for a bypass tube leak. In your shoes, i'd replace both the manifold gasket AND the bypass O rings for a clean sweep. I also use a bead of Silicone sealer just around the water gallery area of the manifold gasket, then i've not needed to get the manifold skimmed. Of course if the manifold mating face is badly eaten by corrosion (Which I HAVE seen) you'd have to rethink.
Tried silicon sealant and it didn't cure the issue. Once I had it skimmed it sealed without any sealant.
It is a rubbish design, the way the bolts are arranged means there is no clamping force at the bottom of water gallery, which is were it seems to leak.
