When Will took the car on it was running twin SU carburettors, so he must have changed the cable and should therefore be able to advise where to source a replacement.
The cable can’t have done many miles, so investigation as to where and why it broke may be precautionary/advisable.
I have to say I’m surprised an OE cable is 95 cm; my perception is they are much shorter!
Managed to get hold of Will. It was an eBay cable he cut to suit. The TR7 one is the same length but has a decent bulkhead grommet.
If needed a bit of cutting may be required but it should not be to much of a job.
In terms of the standard Sprint cable it was either 75cm which may of been the RHD version and 95cm being for a LHD. Either being substantially shorter than what’s on the car.
