More flow will ALWAYS improve cooling.
not true, sorry, if you mean in the context of making the water move faster. ask any half decent plumber/heating engineer with a brain. I've worked with this stuff every day for 6+ years.
if all the pipes and hoses and bores in the engine are made bigger and you make the volume of water moved bigger but keep it the same speed, your flow rate increases and this would be FAR more effective if it were possible. thats why household central heating is all 22mm tee'd off to 15mm pipe, and that shitty micro-bore stuff is ancient history. alas, not possible on an engine, it has to be built with bigger internal bores.
also, ref dave poth's comment about water going through the rad too quick, yep, true, but also if the water goes through the engine too quick it doesnt stay there long enough to absorb sufficient heat.
too many times ive had people on the phone complaining their radiators dont get warm but they've got 2KW + of heat going into the system, the pumps buzzing away and the water is flowing etc etc
ok, this is on space heating/central heating, but the principal is the same.
the solution is (nearly) ALWAYS to reduce the flow rate or usually fit a smaller circulation pump.
just my opinion but why try to make the system more complicated than necessary? 12 vane mechanical pump works a treat, and when its knackered you know about it as it crunches/rumbles, water leaks out if the seals are duff and the nominal running temp goes up gradually. chances are you can get home quite safely and look into the problem.
if ewp dies, or if its controller dies, you suddenly have NO circulation of water, and by the time you realise theres a problem you're well on the way to needing a strip down. then comes tracing the fault - is the pump faulty or is it the controller?
my solution - dont waste your money.
