Trying to compare a Central Heating System to a Car cooling system to me is wrong,
One is trying to keep heat in the other is trying to lose heat.
I really dont want to be tarred with the argumentative brush, but they're actually doing exactly the same job, i.e. trying to lose heat into air.
a boiler burns fuel (whatever type it is), gets hot, heat is transferred to space via water running through radiators in a closed circuit, forced by a circ pump. the cooler water returns to the boiler and is reheated, process is contiuous until the thermostat or timer turns the boiler off. the circ pump generally runs continuously until the heat from the boiler is purged before switching off.
if you dont disperse the heat at the correct rate then something doesnt work, the boiler switches off as it overheats, or if the water moves too quickly it doesnt stay in the heat exchanger in the boiler long enough to absorb the heat to send to the radiators, so the radiators never get warm. its a bit hard to achieve the latter in a household system due to the amount of heat a domestic boiler can produce.
a car engine burns fuel to produce motion, the net result is typically 4-7KW of waste heat that needs to be dispersed, via coolant running through a radiator, forced by a circ pump. the only difference is the rad in a car is a heat exchanger with a big fan, rather than a naturally convecting white metal box filled with water with fins on the back, screwed to your walls.
the biggest difference is a household water heater/boiler churns out 20-30KW, a boat heater can be anything from 2-10KW, so a boat heating system is closer to the heat output of an engine, and those jabsco pumps are fitted to literally hundreds if not thousands of boats.
jabsco pump will do the job just fine, better to just wire it to come on when the ignition is live and run the system continuously with a stat. water coming out the rad will be less than 80 degrees, so the pump goes in the pipe out the bottom of the rad, just like the standard one, but I still reckon on a standard dolly lump to be used on the road, an ewp is a pointless investment. race car or big wopping great engine is obvioulsy a slightly different story. the money would be FAR better spent going towards getting an ally rad made by radtec or the likes of, with extra rows, more fins and a hardcore fan.
if we start talking about fan AIRFLOW rate and how that affects how well the radiator works, thats a different story altogether. in that case, the more AIR flow, the better the rate of heat dispersal.
must........ get......... a............ life..............
heeeeeeeeeellllllpppppp meeeeeeeeeeee.
