Its nice to get a 700 rpm rev drop at motorway cruise but....
The gearbox mounting on all o/d cars is a PITA to use an americanism..
If you use your car mostly around town the extra weight and general bounciness of the overdrive and not quite so slick gearchange means I'd stay non o/d now having had both on the fleet. The o/d cars all regularly blow the downpipe flange too. Ive just put an Alun exhaust support bracket on blue and its now a lot better with a new mount as well. STill doenst feel as tight and smooth as white but its close...we'll see if its still all tight in a few months...
Then there is the gearstick loom and the dodgy gearstick switch and the iffy wiring...all not so nice to get old with...
Bizarrely Ive only ever converted a 3 rail car and the prop was the same.
The zorst is different though..
On a single rail car like yours I'm not sure about the prop but you will need the o/d cross member and mounting, same as a sprint except the bit that joins mount to box...the exhaust is the same.
Its fun flicking in o/d third in that overtaking maneuvre though...
ZF 4 speed auto conversion anyone?
_________________ Note from Admin: sadly Jon passed away in February 2018 but his humour and wealth of knowledge will be fondly remembered by all. RIP Jonners.
