It is currently Wed Apr 24, 2024 7:07 pm
PostPosted: Sun Dec 03, 2006 7:09 pm
Anybody have any info on the geometry the race cars run
camber caster toe etc etc
If its top secret you can pm me it will be kept under my hat
Im on a mission and want to really give the car a proper run on the 29th at donno Absolutley full power as there is going to be some fast cars there
Thanks D
 Post subject:
PostPosted: Sun Dec 03, 2006 9:21 pm
ask the jedi master m8, his car seems to kick ass most of the time he runs it, however you have over 3 times the hp, bigger wider wheels, possibly different weight distribtion etc so not sure comparing to a standard dolly is all that relevant, although may get you somewhere near...
 Post subject:
PostPosted: Sun Dec 03, 2006 9:37 pm
Hope he :posting: some to me :thumbsup:
 Post subject: Front Suspension Setting
PostPosted: Mon Dec 04, 2006 1:01 am
As was stated above, front suspension settings can be very dependant on track conditions, spring rates, shock settings and most definitely what tyres you are using.
As a starting point we use around 3.5 to 4 degress negative camber, castor is similar. Tow in 2mm. As already stated it is personal taste etc. We have are swapping from running Yokohma A032R to A048 for next race season, an thinking of increasing the front spring rate by around 25-30% (500lb +) to get the tyres to "work' better.
 Post subject:
PostPosted: Mon Dec 04, 2006 2:36 am
http://video.google.co.uk/videoplay?doc ... 8+Supercar
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
480Hrs @ 14/03/2024
Working on a ratio of just 7Hrs a day not including driving to the Sprint.
That equals to 68 days that doesn’t include weekends.
Member TDC no 0471
Project 13B Sprint now back on.
PostPosted: Mon Dec 04, 2006 8:29 pm
Mark im running 500lb front springs
and its 1inch lower than standered at front
Im currently running 225 45 16 dunlop dz02g tyres at the front and 265 45 16 rears 350 lb rear springs
Im going to try your settings and see how it performs
I have been experiancing bad understeer i think the rear tyres are just too big
im going to up the rear tyre press a bit and drop the front a couple of pounds,
I just dont have enough time on track to set it up as i only do the odd track day
I usually hold everyone up on the corners and use the power i have to out drag everyone on the straights :woohoo: :woohoo: :woohoo:
PostPosted: Mon Dec 04, 2006 10:31 pm
I vaguely remember a conversation on autocrossing on the old forum where it was suggested that lowering the back relative to the front would help some with turn in. It just doesn't look quite as cool. 8)
 Post subject:
PostPosted: Mon Dec 04, 2006 10:56 pm
Try running it on a soft damper setting at the rear too - I managed to lap Colerne 2 seconds quicker going from full hard to full soft on the shocks.
Or stick a couple of bags of sand in the boot!
 Post subject: Suspension Set up
PostPosted: Tue Dec 05, 2006 10:53 am
ALG1K, I would have thought that with the horespower that you have power over steer would have been the problem.
I have been chasing a chronic oversteer problem , with nothing like the horsepower that you have. The decision to be made, was the front to soft (400lb springs) or the rear to hard (200lb). After a bit of a rethink, the rear suspension was returned to standard, ie all rear arms connected and and panhard rod that was fitted was removed and throw in the bin. Rear shocks (GAZ) were reset slightly firmer and the I acheived about .5 second improvement in lap times. (1m 13sec lap).
With the change of tyres for next year I intend to try stiffer front spring to start with and take it from there. If you still have under steer it might be worth trying softer front springs. When our cars use to use slick tyres (cross-ply construction) front spring ranged from 500-650lb and rear 300-350lb depending on track surface.
It is interesting that many people, us included, will spend much time and money on trying to get more horsepower, when quiet often for a lot less money the car can be made to handle better and improve the lap times.
 Post subject: Re: Suspension Set up
PostPosted: Tue Dec 05, 2006 5:16 pm
I can promote oversteer at a prod of the throttle
Its nice to go into a corner on a trailing throttle and sqirt out
Its just at the moment im getting understeer
Its only happend since i changed the ride height and a couple of settings
Im also running diff tyres
I will try your set up and if its a no no i will try my old set up
I didnt want to go back to it as i wanted a higher ride height
Here is a pick of the ride height and the spoiler has been dropped 1" with a spacer
As you can see its quite high and this is how it raced last week.
 Post subject: Settings
PostPosted: Tue Dec 05, 2006 7:07 pm
I don't profess to be an expert on this subject but i think it is good practice to only change one thing at a time. Otherwise if it does not work properly you have trouble working out what to change next or what part of the change you need to put back as it was.
 Post subject:
PostPosted: Tue Dec 05, 2006 10:24 pm
Wise words Mike...but a bit late for Darren I think! :lol:
Users browsing this forum: DotBot [Bot], Google and 53 guests
