It is currently Fri Apr 19, 2024 9:35 am
 Post subject: MOT Test Brake testing.
PostPosted: Fri Nov 11, 2016 6:14 pm
My offspring took his Renault Clio in for MOT and one of the advisories was....
" High measurement of water content in the Brake Fluid ".
O.K. it was corrected at the service and it passed the MOT but this sounds like a new requirement with an electronic measurement.
I couldn't see it in my old .pdf copy of the manual btw.
Is this just for newer cars ?
Ta,
PostPosted: Fri Nov 11, 2016 6:57 pm
Part of the proposed EU test as its something that is checked in other countries, but not part of the official UK test.
Probably a good thing, you wouldn't want you brake fluid to boil, create steam and get spongy brakes as you hurtle down a steep hill. Still, I'm not sure how often that happens, I suspect next to never and not just as fluid replacement is a basic service item. I suppose it might catch out the odd couldn't give a rats arse to maintenance person with a £100 hack.
PostPosted: Fri Nov 11, 2016 9:49 pm
TDC Staffs Area Organiser
Wasnt aware but will ask the tester when he's in next week.
Probably a good thing to test as so many people don't bother to change it regularly.
PostPosted: Fri Nov 11, 2016 11:14 pm
I've got a customer MOT on Tuesday so I'll see what my tame tester says, but i've not heard of this one and I usually get advance notice from him of new introductions like this. It's entirely possible that it's not yet on the statute book as a RFR, having the testing equipment is voluntary and results obtained thereby only advisory.
Personally, I think it's a good idea. I change the brake fluid on my Cavs every 2 years, as per the service literature and about every 3 years on the Carledo (which is on synthetic Dot5.1 fluid)
But of possibly 2-300 customers that I have, only 3 that I can think of have their brake fluid replaced regularly. I occaisionally do one off changes for specific failures (very rare) and will usually bleed through an entire system if changing more than one metal pipe for MOT, but most of them look at you blankly when you suggest they add it to their service and flatly refuse to spend more money than they absolutely have to. Mind you, the locals round here have a reputation for being "careful" with their cash! I don't much like doing it myself as the potential for doing expensive damage releasing (or failing to release) recalcitrant bleed screws is too high!
I can see the wheel cylinder manufacturers and caliper reconditioners rubbing their hands with glee from here though, since this will no doubt boost their business no end. If only from the snapping off of long undisturbed bleed screws by ham fisted fitters!
PostPosted: Sun Nov 13, 2016 10:37 pm
Its not part of the MOT test, in fact its not allowed as part of the test to even remove the brake fluid reservoir cap - and if VOSA was watching you, it would earn you disciplinary points.... So although its entirely sensible to measure and advise the water content of the brake fluid as part of a service, i would not do so on an MOT...
PostPosted: Thu Nov 24, 2016 9:35 pm
I asked my tester about this, not only is it not a test requirement or a RFR, there are no plans to make it so. And as Matt correctly points out, it is absolutely VERBOTEN for a tester to remove ANY part of a car for inspection, so taking the master cylinder lid off to check is a total no-no. There are NO plans to change this either.
My man says they have a fluid hygrometer but rarely use it, even on services. By coincidence one of my other customers took her uncle's nearly new Skoda into the main dealers for service and phoned me in a bit of a panic when they advised her the fluid had a high water content and should be changed (at a cost of 15 megabucks or so) But this was not on an MOT, so OK. At least from a legal standpoint.
As far as I can see, this is just another legal scam to scare customers into parting with their hard earned! I very much doubt that a less than 2 year old, low mileage (11k) Skoda would actually desperately need it's brake fluid changing!
PostPosted: Mon Dec 05, 2016 5:29 pm
Those little scallywags that work in garages have always been good at inflating their profits.
I remember taking my Sprint into a garage for an MOT and they declared the front tie rods of having worn bushes...................ah but they were new but I had used the old rusty nuts.
Two new shiny nuts and it passed and I never went there again, for anything.
Users browsing this forum: No registered users and 33 guests
