well...progress!!
Dave came down on Saturday and we managed to get the tank out, what a b'stard that was, dont help having such little space, but its out and now i can crack on with the body work!!
First to go on sunday was the wheel arch followed by the rear corner where all i was grinding was filler
then the sill which just fell off really, to say it was rusty is an understatement, im supprised it even stayed on the car!!
the inner structure isn't to bad, the sill reinforcer will need building up at the bottom but the main innersill seems solid!!
Iv got to take the Doors off to enable me to fit the sill properly, sounds easier that it is, they have roll pins in the hinges which wont budge, i havent got the room in the garage to open the door fully so getting to the hinges is some what restricted....lesson learnt!! so the passenger side will be removed before it goes in the garage the t'other way round!!
Some photos of some progress!!
Just the edge of the outter arch removed, inner looks ok and should be a simple repair!
Rear corner slightly removed, didn't want to go to far untill i get the panel
Sill removed, you can see the old one there just happily rotting the car!!
New panel placed on the car, will need alot of trimming before i finally fit it!!
The piles of rust just from these sections removed!
Floor seems solid apart from this little bugger and his mate on the other side!!
Now for anyone willing to help with the resto, you can purchase a peice of rust of the car complete with a certificate of authenticity...all for 50p, im only limiting buyers to 2 peices each due to the demand!! (if this works ill be rich as the whole car is rusty
Im off work on thursday and im hopeing to weld the front end together and start cleaning up the sill etc
Nathan
