It’s been a while so...
Been working on her now for the last two weeks doing bits here and there, Iv fitted the fuel tank on my own...not a easy job, considering it took me and Dave an hour an half to get it out, anyway that’s in, all pips reconnected with one being replaced, handbrake on, exhaust on, the brake pipe I snapped has been replaced, others will follow later!!
Took Friday the 13th off work to work on the car, plan was to get her fired up, turned around to start on t'other side....9am saw me walking down with a cuppa, made sure all fuel pipes were secure, took the pump off and primed everything up, popped on a fully charged battery and turned the key....took about 2 seconds to start (she's a good girl)
Got her out the garage (first time in a few months) and ran her up and down the entry and was let to run up to temp, took off the passenger door to gain access to the sill, took off the wing and noticed iv got a snapped coil spring on the N/S/F, iv got a new one coming...I know you need to replace the 2 but at the moment if I can get that fixed I can do the other at a later date!! After a 75 point turn as the entry isn't that wide and the guy behind parks his car directly opposite she was back in the garage and up on ramps/axle stands!!
I spent a few hours down there last night and IV removed the sill, rear arch and rear corner, this side corner is different to the other side as it houses the exhaust but the repair panel comes exactly the same as the drivers side of a little fabrication will be need for this side!!
To be honest I thought this side was going to be worse as its the kerb side and was most corroded on inspection but after removing the panels it don’t look as bad, iv got to replace the inner sill, but by the rear arch the inner sill looks to be very sound, iv still got to clean up around the jacking point, I can hear loose rust in there so its looking like ill have to replace this swell, I also cut down the rear arch repair panel so it will fit nicer and cleaned up the sill, then me Grinder died so I had to stop, but being a person to never throw something away without looking at it first I stripped it tonight after work and found the bushes had worn to practically nothing so having replaced them and cleaned it up its working 100% now....
Sorry for the long update but it’s been a while!!
Quite a few photos for you lot to look at!! :-
and she's out, im really happy with the repairs to this side even if i do say so myself
Sitting there with her retro fitting 80's grill..standard to GTE versions
Door off...dont ever say triumph dolomite doors are hard!!
The lovely snapped coil spring
Profile of the rear corner on this side
ASTRA VIDEO
Little Video of her running, shes on choke so sounds a little rough, but you should hear her rev up quite happy!!
Nathan
