It's possible to change it but it's a fairly big job. Square headlamps are better at lighting the road, in any case.
I disagree on both points.
Firstly, it is very straightforward for any competent repairer to adapt a "square" headlamp inner panel to accept twin back plates.
I have been in a few different cars using the Toledo/Allegro single lights and can confirm that these are as good as sealed beams but not as good
as decent halogen 5-3/4" round lamps (try XJ40). If you are doing this conversion it will be to fit halogens.......
So the bulbs are what matters? I was kind of hoping it was possible, because I have seen a few lower spec cars, including a few triumph se models (i think that was a 1980 special edition?). I know this sounds shallow, I just don't like the square lamps, the double lights just look so much better.
