It is currently Sat Feb 27, 2021 3:07 pm
 Post subject: Will fit a Dolomite...
PostPosted: Sun May 17, 2020 7:51 pm
This stalk switch will fit a Dolomite :)
https://www.ebay.co.uk/itm/30505-VERY-R ... SwBFlbxdXw
I am pretty sure I have a NOS stock one of these.
Definitely have a NOS indicator stalk.
Maybe I need to get a safe to store them in :) ?
PostPosted: Sun May 17, 2020 7:54 pm
Amazing that they can't even spell STAG correctly!
PostPosted: Mon May 18, 2020 2:32 am
Will it fit a Dolomite?
Only if you had the matching indicator stalk so you swapped both to European convention....and nipped the connector plug off and fitted a Rists pin plug....
 Post subject: Aye.....
PostPosted: Mon May 18, 2020 11:30 am
It does actually fit a LHD Dolomite up to 1973,
but obviously these are not as sought after as a Stage :lol:
PostPosted: Tue May 19, 2020 11:19 am
At that price, I half expected the location to be Doncaster!
PostPosted: Tue May 19, 2020 12:07 pm
You have NOS LHD stalks? If you aren't seriously talking similar telephone numbers, i'd be interested in acquiring them!
PS, don't mind at all if the bottom connectors are not Rists, I can convert!
'72 Triumph 1500FWD in Slate Grey
PostPosted: Tue May 19, 2020 5:51 pm
Yes the left hand ones are the best to get if you can get them at a good price,you can then swap them round to fit right hand drive car and the lettering is the right way up :D
PostPosted: Tue May 19, 2020 7:45 pm
Thought I'd have to go to Jeroen or someone else in Europe to get some!
I'd quite like a LHD column shroud too, then I can put the ignition switch on the correct side too, i've always dislked the switch on the inside of the column!
