An ex club members pride and joy, a very late W plate Dolomite 1850 HL first registered on the 9th September 1980 which makes it one of the last cars to be made.
JMK 907W has always been garaged and meticulously cared for. It is presented in Brooklands Green with beige cord interior, it currently sits on Spitfire wheels with gold coachlines. Both the paintwork and interior look to be in excellent condition, I have seen end of the line dealer specials built up in this way so there is a chance that this could be one of them.
Two former keepers, lots of receipts and spares to go with the car, including a rad with kenlowe fan setup.
The car has been in dry storage since the previous owner passed away, its previous MOT expired in October 2019. It has been started and run up to temperature on a regular basis. Recently the fuel pump has given up and the battery has died, a new one has been purchased but due to the current situation the current custodian of the car cannot get it fitted.
I have attached photos of the car before it was put into the garage, as soon as the situation lets me I will go and fit the new fuel pump, fit a replacement battery, get the car started and tune the carbs with some fresh fuel. I will also be able to run it and test the brakes, suspension, steering etc... I will also be able to take some more up to date photos of the car.
I have updated the post with some photos of the car as it currently sits.
The car has some good points and some bad points. The car appears to be structurally sound. There is some rust in the door bottoms, sills and at the back of the wheel arches in the boot. Nothing that’s not repairable. The front off side wing and nose panel looks to have had some damage and requires remedial repairs. The near side front door similarly.
The car is a good candidate for repair and refurbishment.
There is a brand new and second hand engine block in the garage if needed.
There are some Dolomite related parts in the boot.
Currently asking £1500 as it sits, car is currently located in Upham, Hampshire.
If you are interested in the car please contact me via direct message and I will put you in contact with the owners daughter.
