Is it possible to separate the CV joints on the early props?
Yes.
Wanted to fit a new centre bearing, but cannot fathom how to separate the two halves.
Am I just better off getting it done somewhere, and if so where is best? Or should I revert to the UJ only type. Simpler I guess. Anyone got a spare?
Helpfully, none of the manuals show the CV joint anywhere only the Hardy Spicer UJ's.
It was a long time ago but, I have successfully replaced a Sprint centre mounting. You only need to separate the CV joint next to the mounting.
Indeed the BL manual does not explain how to do this. However someone in the Dolomite Sprint Register wrote an article explaining how to do the job so I followed his instructions. I still have that article somewhere (in fact I have every copy of DSR news....quite sad really
If nobody posts the answer I'll look for the article on Wednesday and let you know then.......
Wasn't there a thread on this very subject last year?
