Wolfrace wheels
merlind100
Wolfrace wheels
#1 Post by merlind100 »
More of a general inquiry than a serious search at the moment, hence posted here and not in the wanted section. I fancy a set of these for the car in 13 or 14 inch, does anybody have any?
Howard81
Re: Wolfrace wheels
#2 Post by Howard81 »
There was a 14" set on eBay recently... I was tempted but not sure if 14" would fit on a Dolly!
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
Oli_88
Re: Wolfrace wheels
#3 Post by Oli_88 »
Iirc, 14" wheels do fit with a bit of work...
I think it was Lewis that posted about them before.
Andybrad
Re: Wolfrace wheels
#4 Post by Andybrad »
My dolly has 14" wheels shod in 185/60 tires with no rubbing, arches arn't rolled but car is at standard height.
merlind100
Re: Wolfrace wheels
#5 Post by merlind100 »
Mine is lowered quite a bit so I suspect that I'll have to go for 5.5x13", It's getting them with a 3.75 pcd that seems to be the problem.
Andybrad
Re: Wolfrace wheels
#6 Post by Andybrad »
Depends on what profile tires you use, I'm lowering my car in the next couple of weeks so I'll just put lower profile tires on if need be. I think some guys have 15's on their dolomites.
Mondeo Owner
Re: Wolfrace wheels
#7 Post by Mondeo Owner »
Spooky.
I decided that a set of "winter wheels" might be worthwhile for mine and spent last night browsing ebay for Minilites then Wolfraces (without success)
What PCD/Offset do I need to look for? (or any other technical stuff?).
I'm in no rush so suggest if you find a set flag it or PM me as I don't want to bid up a set against a fellow forum member.
EDIT - Mine isn't lowered so 14" might be OK for me.
merlind100
Re: Wolfrace wheels
#8 Post by merlind100 »
it occurs that Triumph front ends were popular with hot rodders for a while as were wolfies so it might be possibale to pick up a couple of pairs
mbellinger
Re: Wolfrace wheels
#9 Post by mbellinger »
Wolfrace (back in the day) did a number of applications for the TR7. My own TR7 wore Woolfies for a while.
Those are the boys you need to find.
Martin.
2021 Dacia Duster 1.3 TCe
1963 Austin A40 Rally Car
Mondeo Owner
Re: Wolfrace wheels
#10 Post by Mondeo Owner »
Oli_88
Re: Wolfrace wheels
#11 Post by Oli_88 »
Iirc Stag wheels don't fit, well not without a lot of hassle.
So surely by association wheels for a stag would be much the same. (thinking out loud)
merlind100
Re: Wolfrace wheels
#12 Post by merlind100 »
4.5" pcd on Stag wheels, if I was to go to the trouble of changing that I think I'd go for Fords 4.25" pcd. Many more options then for wheels and brake upgrades
DOLLY76
Re: Wolfrace wheels
#13 Post by DOLLY76 »
OH now I get it! In Australia "Wolfies" are called "Jelly Beans" because the holes in the radius are shaped like jelly beans. Hmmm Now I want a set :P
