Thinking it was the cable i bought a new Dolly one (so as to be correct for my gearbox. I found that the end on the original was oval but the Dolly is square at both ends.
I knew that it wouldnt fit to my speedo gauge as the new cable is held onto the back by a thread whereas the Tolly gauge is a clip on fitting. "So" ! i grabbed out of the garage what i thought to be the correct type speedo gauge. Very similar except it goes up to 120mph on the clock instead of my 100mph tolly gauge, also it has a threaded connection for the cable.
So into the car it went.
Only to find that the nut on my new cable is larger than the thread on the speedo!!!
So what i'm asking is this, What speedo is it that i have and what type do i need to fit the new cable?
Any help is much appreciated as i would love to sort this and finally know what speeds i'm pootling along at.
