Removing the roof 'gutter' trim?
Edin Dundee
#1 Post by Edin Dundee »
Hi All,
How do I remove (and re-attach) the trim that runs along the side of the roof? I need to get to a couple of rust spots.
1300dolly
Re: Removing the roof 'gutter' trim?
#2 Post by 1300dolly »
Very carefully :lol: ..........................................or........
very carefully,,,,,,,,,,,,,,,,,,,, using a rag to protect the trim and a beer bottle opener to prise the trim off, you have to be very gentle and inch it only trying to slightly dislodge the trim bottom edge upwards and not fully remove it then rego along the lengh on the third pass it should pop of, if you try to remove it completly on the first pass it will twist and curl up,go slowly it will take about 30 mins per side.
mahony
#3 Post by mahony »
Make sure you don't lose the clips that hold the trim on as there no longer available.
1300dolly
#4 Post by 1300dolly »
mahony wrote:Make sure you don't lose the clips that hold the trim on as there no longer available.
What clips, there are none on the gutter trim?
Howard81
#5 Post by Howard81 »
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
1300dolly
#6 Post by 1300dolly »
Ahh those clips, umm the last one i done didnt have any!
baz
#7 Post by baz »
Yep..... I'm with 1300Dolly , done a few of these chrome strips now and never seen any clips??? The things are on that tight you wouldn't need any clips ...surely?
mahony
#8 Post by mahony »
baz wrote:Yep..... I'm with 1300Dolly , done a few of these chrome strips now and never seen any clips??? The things are on that tight you wouldn't need any clips ...surely?
Howard has posted a pic showing the clips !!,check the parts catalogue part no zkc1298 ( only fitted to cars from VA9547 onwards ).
1300dolly
#9 Post by 1300dolly »
mahony wrote:only fitted to cars from VA9547 onwards.
That explains why I have never seen them, I've never owned a sprint.
