I resleeved my block, standard sleeves are about £19 each (S&S Preps), but to have them fitted a crank grind and shells, head skim and all moving parts lightened and balanced added a further £600 to my bill!
I was wondering what kind of bearing shells i do need? I've read vandervell? And where do i get them? Or are the shells from rimmers good enough?
Is it neceserry to balance all of my rotating parts? And lightening?
I was thinking of bying a new 2 litre engine block from rimmers for 490 euros.. this because resleeving a 1850 block isn't that much cheaper i think...
Then my crank needs to be regrinded at the big ends.. And it has been done before i think. If you look at the number at my first post..
But some people told me the cranks aren't that strong so regrinding isn't recommended.. what do i have to think of that?
Rimmers isn't rubbish but the bearings that are of the make County are. Had these in my engine and lasted 20.000 miles. Replaced by Vandervell and now 140.000 further still going strong. Even with this happening:
So i do need some Vandervell Bearings. I've been searching on the net but they are hard to find. I've found some but they are +30 and +40. But i need some STD bearings for big end and main.
Then i've heard of other bearings such as Glyco and other trimetals... Is it any good? When yes.. where do i get them from?
Hi everybody, it is time to put some update on the forum about the restoration of a Dolomite Sprint. The Dolomite 1850HL is not being restored but actually in full service ! It has been used for vacations and work and of course it broke down several times but as many times repaired. It is tomorrow December 5th and that day makes our Dolomite 1850HL a 40 year old car, which means cheap in tax !
The reason that I did not update this forum is that I was (and still am) very very busy studying at the University of Eindhoven and really that's taking my time entirely. I couldn't work on cars either because there was just no time. But my father (he's also involved in this project) has done some work on the Sprint and he will update this he said with some pictures.
Greeting
Reason:Resized the photo.
