The project has taken a big leap forward following the installation of engine and gearbox all sitting on its subframe. I used the up and under method which I had trialled earlier and which has been used by others.
The car was rolled on its four dollies in under the hoist and the first step was to lift the car sufficiently which allowed the slave (1850) subframe to be unbolted and moved out of the way.
- 20121127-3676Pw removing slave subframe.jpg (130.39 KiB) Viewed 4365 times
Then it was a simple matter of lifting the car higher until the complete engine assembly could be wheeled in under the car
- 20121127-3683Pw Engine iin position.jpg (134.57 KiB) Viewed 4363 times
and it was lowered down until the lower front shock absorber bushes could be attached. It was necessary to jiggle and rock the car a little so that the exhaust manifold bolts cleared the side of the chassis rails and at the same time it allowed the inner wishbone mounting points to move into their correct position, tucked up close to the inner wheel guard.
The two shock absorbers helped to guide the assembly down onto the subframe itself. The rear upper mounting rubber bushes were pushed up onto the tubes on the chassis rails and I attempted to do the same with the front upper mounting rubber bushes although they tended to fall off just at a critical moment so I left them sitting in the subframe. When the car until it was about an inch clear of the subframe I dropped the front bolts down through the front upper bushes and it guided the whole assembly into position.
I then bolted up the two front bush assemblies making sure I had the engine stay bar bracket on the left hand bolt.
The gearbox was jacked up slightly using a bottle jack. At this point I discovered that I had installed the rear mount on the gearbox facing backwards instead of forwards but it took not a great deal of time to unbolt it and turn it around and then bolt the gearbox mount into place. Finally the rear subframe bolts and bushes were bolted up.
- 20121127-3687Pw Engine installation complete.jpg (123.94 KiB) Viewed 4362 times
It was time for a cup of tea and to realise that it was the first time in over 20 years that the engine assembly had been reunited with the car.
By late evening, after the front wheels had been refitted, the car lowered onto the front dollies and the lifting beam removed, the car was moved from under the hoist back around into the workshop on the other side of the wall seen in these photos. Then the engine stay bar, fan and radiator were installed.
It completed a very satisfactory day’s effort.
