oh no, not a Triumph 2000
Re: oh no, not a Triumph 2000
#16 Post by Jon Tilson »
Sweet cars those....
My first Triumph....drove me to the Matterhorn and back. Quick in there day too.
swifty
#17 Post by swifty »
ooooooo! TR6 wheels as well! - There's a lot of T2000 owners who would like to do that mod, but finding TR6 wheels can be difficult and pricey... so that's a bit of a bonus...
Triumph1300
#18 Post by Triumph1300 »
The TR6 wheels are courtesy of Carledo (thanks Steve)
The latest update is it runs nicely, doen't appear to have any major rot, and has mk 2 manual/od running gear.
Ken,
I've gotta get that exhaust off you
Brake cylinders ordered, progress started!
Interior wise, the seats, doorcasing, and veneers are fairly good, it needs recarpetting
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
Well.......
#19 Post by sprint95m »
Triumph1300 wrote:The latest update is it runs nicely and has mk 2 manual/od running gear.
That is sort of good news.
Mark 2 engines have 7/16" head studs so don't blow head gaskets :)
but,
the mark 2 2000 is encumbered with a ridiculous inlet manifold and the wrong cylinder head :shock: .
However, the good news is that it is possible to fit a skimmed 2500S head and adapt its (HS6) manifold to take Strombergs
or get the original manifold improved.
Chris Witor can relieve you of loads and loads of cash.........
PS TR6 wheel still available........
Triumph1300
#20 Post by Triumph1300 »
The head isn't standard..................... :thumbsup:
TR6 wheel wanted,
BWJ
Reg
#21 Post by Reg »
That is fabulous! :eyes4u:
Runs nicely and no major rot..congratulations 8)
It has a wonderful, gorgeous patina..so just a clean and the bare minimum of work and replacement then? :mrgreen:
#22 Post by Carledo »
Triumph1300 wrote:The head isn't standard..................... :thumbsup:
TR6 wheel wanted,
Is that for a spare, Bruce or is one duff?
Triumph1300
#23 Post by Triumph1300 »
For a spare Steve, the other 4 are fine thanks, and look happy in there new home
BWJ
Purplebargeken
#24 Post by Purplebargeken »
I know you do Bruce but I am kind of getting attached to them. Umm, I guess I might rephrase that.
Bruce, I cleaned off all the rust from a couple of the mild steel sections (not the stainless bits). It looks a lot cleaner now but I would suggest you invest in a tub of B & H Deox Gel and lather these bits with it. There is a lot of pitting and then you could spray it with weld thru primer for a stock finish and good heat and rust protection. Just a thought though.
Triumph1300
#25 Post by Triumph1300 »
Assuming my sums are right, with an auto diff, overdrive, 15 inch wheels, and 165 tyres, this thing will be geared for about 25 mph/1000 rpm in 4th overdrive.
Comments?
BWJ
#26 Post by Carledo »
HMMM! I had a 2500S Estate, an auto converted to man O/D and with a 2000 TC engine and the obligatory Stag 14" alloys with 185/70s. So the gearing was probably pretty similar to what you have!
Granted the body was heavier than yours both by being a mkII AND an estate, also the 2000 TC is the most gutless of all the sixes, still it was exceeding sluggish off the mark and hated hills, even on the motorway.
I'd consider a lower diff, but try it first, I had a GT6 which ran 25mph/1000rpm (3.27 axle and O/D) and that went fine till the diff exploded and I dropped it to the stronger 3.63 at 22.8/1000.
#27 Post by Jon Tilson »
Minty lamb site has all the gearing and tyre combos you could ever want....
if you do 25 a 1000 you are in the middle of the torque curve at motorway cruise. It should also still pull 4k and give you the ton on the continent.
As long as its not geared too high to move off loaded in 1st its not that much of an issue....you can always change down higher up....:-)
Triumph1300
#28 Post by Triumph1300 »
Right then,probably the wrong forum to ask this on, but..........
I've been offered a lhf wing for the 2000, at sensible money.
How much more difficult is a 2000 wing to fit than a Dolomite?
BWJ
Triumph1300
#29 Post by Triumph1300 »
Ok, not much progress in terms of actual work, but lhf wing has been acquired, the correct starter is hopefully turning up tomorrow, and rear wheel cylinders have been ordered.
Just need to get holiday, and work out of the way, and work should start in earnest.
BWJ
swifty
#30 Post by swifty »
Lots of piccies please! :wink:
