MSO 662P
maximus
Re: MSO 662P
#61 Post by maximus »
Seen these and loved them
Re: MSO 662P
#62 Post by soe8m »
I like this type of rearlamps.
Tony Burd
Re: MSO 662P
#63 Post by Tony Burd »
Subframe on
Back on its wheels
Hopefully get the back axle on tomorrow.
shep
Re: MSO 662P
#64 Post by shep »
Looking gorgeous!! Gonna be fantastic when it's finished!! Very inspiring !! Keep the updates coming!!
Cheers, Shep
Tony Burd
Re: MSO 662P
#65 Post by Tony Burd »
Cheers for that, keep the comments coming as sometimes it's difficult to keep the motivation going.
Had a crap afternoon on Sunday, the car came with Polybushes fitted to the rear trailing arms which I stripped out to have the arms refurbed, when I tried to refit them I could not get them in enough as they are the type in two halfs, this meant it was impossible to fit the arms to the axle.
So I have ordered Superflex 'Cotton Reel' type bushes, it really is a false economy using cheap copies, I wasted about 3 hours messing about .
When you have a freshly painted car the last thing you want to be doing is using a crowbar & hammers to make things fit.
So hopefully have another go this weekend.
Ron1966
Re: MSO 662P
#66 Post by Ron1966 »
Looks stunning Tony. Love the colour. Now the interior has got to match the superb quality of the body and running gear especially that engine. Will you be adding the vinyl roof.
Down&Out
Re: MSO 662P
#67 Post by Down&Out »
Do you know what headlamps were fitted to original blue MSO? They look sort of E30 ish.
Super work so far.
Tony Burd
Re: MSO 662P
#68 Post by Tony Burd »
I've got a Rover 45 leather interior to go in, so should look nice.
The paint is so good I might not bother covering the roof, although I might go for a carbon fibre wrap.
The original headlights have Halogen stamped on them & have flat lenses, not sure where they were from.
Cheers for the comments, the super flex trailing arm bushes turned up so hopefully will get the back axle on.
Purplebargeken
Re: MSO 662P
#69 Post by Purplebargeken »
Good on you for not going the vinyl route. The wrap will look very interesting indeed and I look forward to seeing it done. Great resto.
Ken
Tony Burd
Re: MSO 662P
#70 Post by Tony Burd »
Still struggling with these trailing arms, the Superflex bushes arrived but seem to be impossible to fit using the vice, so will need to find a friendly garage with a hydraulic press to get them fitted, or has anyone on here got a press in the Hampshire area?
Reg
Re: MSO 662P
#71 Post by Reg »
Tony Burd wrote:Still struggling with these trailing arms, the Superflex bushes arrived but seem to be impossible to fit using the vice, so will need to find a friendly garage with a hydraulic press to get them fitted, or has anyone on here got a press in the Hampshire area?
Hi Tony, I had trouble with those in the vice too.
Try a long nut and bolt with two large washers..worked perfectly for me every time. :)
Tony Burd
Re: MSO 662P
#72 Post by Tony Burd »
Hi Reg,
Good idea, funny I was talking to a guy at work about it today & he suggested the same thing, he used the same technique for bushes on his Mk2 Cortina.
Tony Burd
Re: MSO 662P
#73 Post by Tony Burd »
Just tried it works a treat, still a bit tricky as the bush wants to skew, but as long as it is all lined up it pops in, thanks.
1st one in, 3 more to go!
Tony Burd
Re: MSO 662P
#74 Post by Tony Burd »
Back Axle is fitted, no more polybushes to fit, hooray!
Flyfisherman
Re: MSO 662P
#75 Post by Flyfisherman »
All nice and shinny paint work - shame the shocks and spring didn't get the same treatment.
Regards
Paul
