MSO 662P
Down&Out
Re: MSO 662P
#106 Post by Down&Out »
Superb work as per.
Im using an LED strip similar to the way youve done yours, should have a better light output than the original too.
Tony Burd
Re: MSO 662P
#107 Post by Tony Burd »
Bit more done today.
Heat shield fitted
Bulkhead pad fitted
Loom fitted
Brake pipes fitted
Clutch master cylinder fitted
Servo & brake master cylinder fitted.
I bought the brake pipe set from Stevsons, the 1st pipe that goes from the 4 way splitter to the rear axle seems too long, bit of a pain as I need to now shorten the 2nd pipe, just need to find someone with a pipe flarer, or I haven't routed the pipe correctly, have a look-
Re: MSO 662P
#108 Post by Mad Mart »
Yes that first pipe is way to long. It should end just before the handbrake area with a union to the next bit which goes to the LSV.
grifterkid
Re: MSO 662P
#109 Post by grifterkid »
WOW!!! That is looking superb...
Tony Burd
Re: MSO 662P
#110 Post by Tony Burd »
Cheers for the comments.
Why is the pipe to the back axle in two pieces?
I think I will call Stevsons next week to see if they can either make me a shorter 2nd pipe or replace the 1st section, plus they need to know the set they are supplying is incorrect, unless mine is a one off mistake.
Nothing done today, family day at the Newbury show, great show by a Spitfire & Hurricane, shame the Lancaster didn't make it. Might do a bit tonight while the other half watches the new series of Downton Abbey, yawn.
Tony.......
#111 Post by sprint95m »
Not being funny, but is it really wise to use a screwdriver to lock an axle stand?
Tony Burd
Re: MSO 662P
#112 Post by Tony Burd »
Yeah it's fine, it's quite a chunky screwdriver, plus there is not much weight, engines not in yet.
Any enlightening comments about the brake pipes?
lwalton
Re: MSO 662P
#113 Post by lwalton »
If I was nearer I would pop over and flare you a new pipe but it is a bit of a drive!
Tony Burd
Re: MSO 662P
#114 Post by Tony Burd »
Cheers Lee, shame you're not closer would save me a bit of hassle. It's annoying when you plan to get something done & you can't finish it because the parts are wrong.
Oli_88
Re: MSO 662P
#115 Post by Oli_88 »
I have a flare kit, only up the road too... It's a cheapy, but it worked well on the kunifer pipes I made for the front of my car after rebuilding the calipers.
More than welcome to borrow it, though if you can get hold of a decent kit, I'd do that!
Hit it.
Tony Burd
Re: MSO 662P
#116 Post by Tony Burd »
I might take you up on your offer, will speak to Stevsons first see if they will send me a new pipe FOC.
Hi again....
#117 Post by sprint95m »
Tony,
if you have no joy with Stevsons,
PM your contact details and the length of pipe required, then one will find its way to you :) .
Tony Burd
Re: MSO 662P
#118 Post by Tony Burd »
Thanks Ian, that is a kind offer, this forum really is a great place!
I need to get in the garage & take the measurement.
I will speak to Stevsons hopefully tomorrow as I met them at Beaulieu Autojumble a couple of weeks ago, they were selling Goodridge type braided flexi brake pipes. I didn't know that they can make up their own flexi pipes to any spec you like, so again I need to take some measurements, then I am going to get them to quote for flexi pipes to go from the rigid pipe under the front wing to the Sierra caliper on the trackerjack conversion I have. That way if I order those I am sure they will remake the front pipe which is wrong. If they don't you will be getting a PM.
This is what i did.......
#119 Post by sprint95m »
Tony Burd
Re: MSO 662P
#120 Post by Tony Burd »
Yes I have seen this thread, I want to do something similar but with a single flexi from the caliper to the brake pipe fitting at the inner wing similar to merlind100? but I'd rather get something made up, I do not have enough experience to make my own.
