THX 759M Sprint
jeffclane
Re: THX 759M Sprint
#31 Post by jeffclane »
Thanks Jon
Have sent you pm
grumpyoldtimer
Re: THX 759M Sprint
#32 Post by grumpyoldtimer »
Some nice work going on there!
I am also restoring a yellow 'M' plate sprint. What year and number is this one?
jeffclane
Re: THX 759M Sprint
#33 Post by jeffclane »
Its VA 1617 and it gonna be a bit of a weldathon i reckon......
jeffclane
Re: THX 759M Sprint
#34 Post by jeffclane »
I Did trial fit the outer sill to check all sill components fit, bit of tinkering and all seems not too bad. You can see the front foor gap looks big, but i didnt have the door aligned correctly, should line up with the rear ok. There had been two repairs to the sills previously which meant the lip on top of outer sill was quite high. I've still got to dress that area with grinder.
jeffclane
Re: THX 759M Sprint
#35 Post by jeffclane »
You can see the state of the rot at base of pillar. Have cut out rot and started to repair. Did make mistake with fabriaction which set me back. Looks like it steps back a bit to fit the end of outer sill (jonners is sending me end or NOS outer to help - many thanks! :D )
dogrich_0
Re: THX 759M Sprint
#36 Post by dogrich_0 »
jeffclane wrote:Its VA 1617 and it gonna be a bit of a weldathon i reckon......
Mine is 1606 yours would ave been just been behind ! Keep going , best of luck
jeffclane
Re: THX 759M Sprint
#37 Post by jeffclane »
have been working on the sill end which has been tricky. Couldn't tell what the end looked like due to the rot, got some ideas from pics and also on here. The easiest way seemed to use three triangular shapes and go from there. Was also thinking that it was pretty much unseen anyway! had to do some work at the bottom of pillar also. Nearly there for this part, though am thinking of just tacking on outer sill and then getting spot welder from hire shop when opposite side is done. Am sure some will not like appearance, let me know!
from front
from front
Camera Pics Mixed 010.jpg (20.39 KiB) Viewed 4838 times
Camera Pics Mixed 009.jpg (24.51 KiB) Viewed 4838 times
Re: THX 759M Sprint
#38 Post by Jon Tilson »
Was that bit I sent you no use then Jeff?
Appologies if that is so...it came from a good home...
jeffclane
Re: THX 759M Sprint
#39 Post by jeffclane »
I'm not sure if it was for that side, I couldn't really figure it out to be honest! It gave me idea of how to get round the problem though. Cheers anyway Jon.
jeffclane
Re: THX 759M Sprint
#40 Post by jeffclane »
Long time since last update. I've recently been cutting out the rot in the screen corner and welding new in, its not looking too bad...hopefully!
IMG_1251 (640x480).jpg (160.49 KiB) Viewed 4419 times
IMG_1250 (640x480).jpg (154.29 KiB) Viewed 4419 times
Re: THX 759M Sprint
#41 Post by Jon Tilson »
Nice work....keep it coming.
lazeruspete
Re: THX 759M Sprint
#42 Post by lazeruspete »
excellent work!
how much left have you got to do? :)
Pete
viewtopic.php?f=19&t=23031
Proud TDC Member!
jeffclane
Re: THX 759M Sprint
#43 Post by jeffclane »
Loads....
Got to do the sill on opposite side then the front panels, then the rear panels. A few yrs away yet!
lazeruspete
Re: THX 759M Sprint
#44 Post by lazeruspete »
jeffclane wrote:Loads....
you're already a few years into it! incredible. i shall watch with interest :)
Proud TDC Member!
jeffclane
Re: THX 759M Sprint
#45 Post by jeffclane »
Out with the old....
In with the new!
In with the new!
IMG_1311 (480x640).jpg (169.8 KiB) Viewed 3376 times
IMG_1294 (640x480).jpg (195.89 KiB) Viewed 3376 times
IMG_1292[1] (640x480).jpg (216.63 KiB) Viewed 3376 times
