Sprint power steering
Re: Sprint power steering
!. View of the lower shaft which is made up of top portion of Fiat lower shaft with U.J., sleeve and lower 3 inches of Dolomite shaft.
2.Fabricated bearing carrier with bearing and upper thrust.
3.close up of shaft
4. Bearing constructed
5.Shaft and bearing assembled
When assembled the shaft goes through the firewall, through the lower bearing assembly and then through the usual Dolomite bearing on the other side of firewall. Now on to the wiring, I will complete this when I get the new fuse box installed. Once I get the steering installation completed I will look to rebuilding the dash and heater assembly. I am considering modifying the heater and replacing the matrix and heater box with a smaller unit with a higher output from Demon Tweeks, it will mean that not all the heater controls will work as now but will have a better output and save on space under the dash as I have plans to fit a tracker system to the car and that space under the dash would be an ideal place to fit it. I already have the tracker unit bought for a different car and never fitted. Be useful in this car especially as now I no longer have a steering lock.
IF ANYBODY IS INTERESTED I HAVE A COMPLETE CORSA C ELECTRIC STEERING UNIT WHICH I DO NOT NEED, should anybody fancy doing the change on their car. It is based in the Stourbridge area of the West Midlands for collection or could be posted at new owners expense
Hi, I'm currently trying to do the same thing. Started with a corsa column and now thinking its too big so looking to the fiat unit.
Wondered how you are getting on and whether the GM ecu and fiat column do work OK?
Any update would be appreciated.
Looks like a tidy fusebox setup, where did you get it?
I'll get round to it - some day!
Not quite finished it yet due to weather and the need to work outside mechanically it is finished but have some electrical work to do yet am in the process of moving the battery into the boot out of the way to give more room in engine bay. Toying with the idea of fitting HID lamps and including the headlamp washers and levellers which are required. The original battery position is being used in that bit.
As to the fusebox can't actually remember where i got it it was on line, i will sort out the invoice and post reply soon
Fusebox came from ECS Electrical Car Services dig into their on line catalogue and you will find it it's about £26.00 though. Jez
Thanks; I'll take a look.Reme5969 wrote:Fusebox came from ECS Electrical Car Services dig into their on line catalogue and you will find it it's about £26.00 though. Jez
My Latham is currently running a 10 fuse box, but it doesn't have any facility for busbars. I had to solder some brass rod to it; it works but could be tidier.
That is what caught my attention with this one far superior to anything else i had seen and perfect for our cars, i thought anyway. Jez
Perhaps you could give us an update when you have got it working. Also will the Dolomite plastic nacelle cover fit onto the modified column?
Yes will do, the plastic cover fits over ok with a bit of work and some brackets fitting to support it internally.
Hi Reme5969,
PaulB wandered if you had got your power steering going yet?
We have installed ours but it is a way off testing yet.
- 16406811_1384283821611358_5968753886833559236_n.jpg (62.31 KiB) Viewed 1270 times
It isn't Orange!!!!!!
Has any one got there power steering working yet ? what parts are needed,what year is the Corsa C
thanks Dave
thanks Dave
Gez's car (reme5969) is in my yard now for finishing up as his health is not so good. Sadly, it is back on normal manual steering and the modified column has been sold (to whom I don't know)
