Shaunshaunroche wrote:AVO suspension.....how the hell do these front top mounts go together.....not like this Shirley?
I can see the next image is correct but not the one above???
I thought it may go underneath the top mount but there is a welded flat in stopping it....
Or....do the red nylon bushes go on the front damper and both sit on top of the top mount....poking through the damper turret?
any thoughts o'wise ones?
The rubber bung sitting inside the spring should not be there - the coil spring must be seated against the shock / body mount plate.
Second picture is correct
Never seen a washer welded on there before - Jon, Martin, Trackerjack & Tony maybe able to explain the reason for the washer
