Cross drilled crank
mikew
Cross drilled crank
#1 Post by mikew »
Can some one tell me if all Sprint cranks were cross drilled ?
I have finalled stripped the water seized engine I bought and reclaimed the parts I wanted - water pump, jackshaft and a few other items, and found the crank is cross drilled - I wondered if they stopped cross drilling (like on the early 2.5 6 pots) later in production - the crank is good at -10 and wondered if it was worth keeping.
Re: Cross drilled crank
#2 Post by xvivalve »
No, not all were cross drilled and yes, its well worth keeping!
mikew
#3 Post by mikew »
xvivalve wrote:No, not all were cross drilled and yes, its well worth keeping!
Thank you
#4 Post by Jon Tilson »
If the jackshaft has no play in the block then I'd keep the block too.
mikew
#5 Post by mikew »
Jon Tilson wrote:If the jackshaft has no play in the block then I'd keep the block too.
The block will need a 40 thou over bore and I'm not too keen on that - doesn't leave much meat in the firerings, but I get you point, could always liner it
#6 Post by Jon Tilson »
If you can find good 40 thou pistons I'd go for it. You can always ask the guy who makes head gaskets to do you
one to match.
jonners
dailysprinter
#7 Post by dailysprinter »
I've run +40s on my modified sprint and I've not had any problems.
1979 Triumph Dolomite Sprint Highly Modified
2006 Triumph Sprint St 1050
2012 BMW 318d Touring
