2 inch carbs
2 inch carbs
Can anyone help with the best jet and needle setting for 2 inch su carbs. Going on to my sprint.
Re: 2 inch carbs
According to my old Triumph Tune manual you should definitely get HS8s fitted with the 125 jets (six pot Jaguars had them from memory) not the 90 type jets as fitted to Rovers.
Use the UE needles up to sports air filter and exhaust.
Use UM needles for the above plus a 'Road' camshaft.
Then for anything more extreme, camshaft wise, use UV needles.
Re: 2 inch carbs
What kind of choke linkage will you use - if any?big trev wrote:Can anyone help with the best jet and needle setting for 2 inch su carbs. Going on to my sprint.
I have looked around for the parts and cannot find any.
Russ Cooper
Dursley
UK
Dursley
UK
- VanIsleSprint
Re: 2 inch carbs
Carl is running HS8s on his car with BAW needles and .100 jets.
I made my own choke linkage for HS8 carbs.
- HS8 MKC.jpg (140.81 KiB) Viewed 6957 times
- HS8 M CH.JPG (927.01 KiB) Viewed 6957 times
DOUG
1980 Dolomite Sprint lhd
