DOLOMITE SPRINT VERNIER CAM SPROCKETS
Re: DOLOMITE SPRINT VERNIER CAM SPROCKETS
Thanks guys, besides I heard the std cam isn't always at 106 degrees. There's some margin to take into account. So after finding TDC a vernier would be very convenient in stead of just make some holes at 2 degrees retarded position (the cam shaft has to be at 108).
Is there a good "idiots guide" on how to set a cam up using the vernier sprocket?
I am going to use one on a new engine and it would be good to know what mistakes to avoid.
Russ Cooper
Dursley
UK
Dursley
UK
If you purchase a vernier sprocket I'll expect a setup manual to be included. If you perform a search on Google you'll get plenty information about past projects. Here's a video:
https://www.youtube.com/watch?v=la6-EgnCOl4
In short something like this:
- find TDC on cylinder 1
- find specified timing point (like 108 ATDC)
- find full lift at inlet valve cylinder 1
- match!
- match!
