It is currently Sun May 05, 2024 2:39 am
PostPosted: Tue Jul 07, 2015 10:00 pm
Am I correct that late Sprints had a different rear brake cylinder to earlier Sprints?
I cannot find any reference to this in the parts book and Rimmers don't indicate any difference either.
If they are different, what is the difference and when did they change. Part number for the late cylinder would be much appreciated.
Thanks.
PostPosted: Tue Jul 07, 2015 10:08 pm
The Sprint was the only model in the range to keep the same cylinder throughout: GWC1121
PostPosted: Tue Jul 07, 2015 10:15 pm
Unconfirmed information is that dual circuit brake cars use the 1850 rear cylinders which have a slightly smaller bore. But my parts list is only a 76 one and though it shows the tandem master (for foreign markets) it only shows one rear cylinder. Perhaps someone will come on who has a very late parts list (80 or 81) though I suspect BL had gone over to microfische by then.
PostPosted: Tue Jul 07, 2015 10:32 pm
It's the other way round Steve, later dual circuit 1850s used the Sprint cylinder.
PostPosted: Wed Jul 08, 2015 10:28 am
For 1500 cars it is the same the later cars with a dual braking system use the smaller rear brake cylinders.
PostPosted: Wed Jul 08, 2015 1:41 pm
I have the late Dolomite parts book dated Feb 1981, RTC9822CB, which, as Alun says, only lists the GWC1121 for the Sprint.
The same GWC1121 is also listed as fitting 1500 / 1500HL / 1850HL for WF68200 and onwards for RHD cars. ( WF68823 for LHD cars. )
PostPosted: Fri Jul 10, 2015 8:39 am
There have been a number of previous posts on this and there ARE two different diameters fitted depending on whether the master is single or tandem. The problem is that as the smaller diameter for later cars can be retrofitted (in pairs) to earlier cars without issue, BL seem to have continued with the same part number. As BL would in the later times have only sold the smaller diameter which work without problem on earlier cars, they never considered the implications that in 35-40 years time copies of the earlier, larger diameter cylinders would be made with the potential for them to be fitted to later cars.
As this post reports, both 3/4" and 5/8" cylinders are being sold under GWC 1121
viewtopic.php?f=4&t=15689
Interestingly, when I measured mine, I came up with sizes 1/16 larger for both, but I'm sure that is my cack-handed measuring.
You definitely need to ensure that only the 5/8" (smaller) versions are fitted to dual circuit systems as if you fit 3/4" versions, you could suffer dire consequences if the front circuit fails as you are effectively back to a single circuit system with the master unable to push enough fluid to fill two larger diameter rear cylinders!
I presume you need to ring any potential supplier and ensure that the GWC1121 they have for sale is the 5/8" (smaller) version if you are fitting to a later car.
Geoff
PostPosted: Fri Sep 17, 2021 11:12 am
Geoff, my Sprint is a Feb '75 production with single line brakes. A few years back I replaced a leaking left rear cylinder which has let go again. On removal I see it is a 3/4" bore (it was not a genuine Girling/Lockheed part and the manufacturer is unclear). I am about to purchase 2x NOS Girling 5/8" bore cylinders - reportedly with newer seals fitted - and plan to replace the opposite side as well - which is not currently leaking. Question is: Is the 5/8" bore
going to work OK?
PostPosted: Fri Sep 17, 2021 11:15 am
Here are two pics of the cylinder to be replaced:
PostPosted: Fri Sep 17, 2021 11:21 am
The 2nd pic above is vague - here is a clearer pic:
PostPosted: Fri Sep 17, 2021 10:31 pm
going to work OK?
The problem is, they all LOOK the same! The only way you can tell the difference is by measuring the bore. The reason for the change is that a dual circuit master has 2 travel gaps on the 2 concentric pistons, making for a longer pedal. Since it would be folly beyond even Triumph's capacity to reduce the front caliper pistons to compensate, the only leeway is in the rear cylinders.
The same thing applies if you have the "Trackerjack" vented disc conversion, the bigger 54mm pistons of the Ford calipers (stock is 48mm) make for a longer pedal, fitting the smaller dual circuit rear cylinders helps to compensate for this. Of course, if you have dual circuit AND Trackerjacks like I do, you just have to live with a slightly longer pedal.
In terms of brake efficiency, you are unlikely to notice any difference using the 5/8" cylinders. The pedal bite point may be a touch higher and that's IT!
PostPosted: Sat Sep 18, 2021 12:42 pm
Thanks Steve. I have measured the cylinder bore diameter and it is 3/4" but, as per the pics, it was an unknown aftermarket part. Not sure what I have on the other side yet. Think I'm going to get a pair of the 5/8" wheel cylinders and replace them both. Makes sense I suppose as I have only to bleed the system once.
Users browsing this forum: Amazon [Bot], Google, Trendiction and 3 guests
