Chassis plate stamping
#1 Post by tony g »
On another note, I want to get a new chassis plate as mine has been stamped badly. Does anyone do the stamping so it looks nice? I dont want to choose the wrong size/font or hammer them too hard that its like braille on the back. What do folks do with them ?
Re: Chassis plate stamping
#2 Post by xvivalve »
I have a set of number and letter stamps Tony, they aren't exact to OE, but then you see a variety of shapes and sizes on the cars, particularly between old style and later style chassis plates.
#3 Post by tony g »
When you get a chance Alun could you measure the height and width of a couple of letters/numbers for me? Ive got some stamps too so if they are close to the same I might try mine.
Maybe a zero and an I would be a start?
#4 Post by Jon Tilson »
What about those jewelry bracelet engravers?
Mayne worth a try...
#5 Post by tony g »
Yes someone else suggested that too. If I had the rough size of the numbers they may do a neater job than me.
cliftyhanger
#6 Post by cliftyhanger »
Bill ate Rarebits offers a stamped commission plate service, and knowing Bill it will be correct. May be worth an email?
#7 Post by tony g »
thanks Clive i never knew that. Ill try him first
#8 Post by xvivalve »
Meanwhile, I'll measure mine tomorrow...
#9 Post by tony g »
Thanks Alun, I havent been on today car trouble grrrr . First legal day on the road and it decides to fuel starve so tank check for debris is my first joyful task tomorrow. :evil:
I knew I should have put a modern set up in there to get some confidence.....
Magenta Auto Sprint
#10 Post by Magenta Auto Sprint »
Looking at mine I think they are 3/16ths wide or 4.7 mm, nearest nowadays is 5mm.
Malc
#11 Post by tony g »
Thanks Malc, what number did you measure?
Magenta Auto Sprint
#12 Post by Magenta Auto Sprint »
Tony,
most of the characters are the same height and width with the exception of 1, I but all the others are the same width.
hope this helps
Malcolm
#13 Post by tony g »
ok thank you :)
TrustNo1
#14 Post by TrustNo1 »
cliftyhanger wrote: Fri Jul 31, 2015 9:48 pm Bill ate Rarebits offers a stamped commission plate service, and knowing Bill it will be correct. May be worth an email?
He will only stamp plates he has supplied. (or at least that's what he said on the CT forum a while ago)
