Sprint Timing Chains
- trackerjack
Re: Sprint Timing Chains
Oh and to think a little strip of spring steel used to be the norm in the past, and never caused a problem.
Jon, that was way before the full hydraulic age.trackerjack wrote:Oh and to think a little strip of spring steel used to be the norm in the past, and never caused a problem.
- trackerjack
soe8m wrote:Jon, that was way before the full hydraulic age.trackerjack wrote:Oh and to think a little strip of spring steel used to be the norm in the past, and never caused a problem.
It may have been advanced to Triumph but Jags had hydraulic 20 years earlier!
- trackerjack
Well if I was racing a sprint engined car I would build it with a solid cam guide possibly made from Nylatron or Nylon 66 and when the engine rattled a bit just move it in a touch.SprintMWU773V wrote: I'd be interested to hear from the racers on here as to what tensioners they use as I don't imagine they are Rolon ones.
Race engines would be rebuilt each year anyway so the wear would not be an issue unlike a broken tensioner which kills the engine.
Inspired by Carledo's recent post in this thread:
viewtopic.php?f=4&t=30306&start=45
I thought I'd Google the SAAB 99 chain tensioner. The first item I found was:
http://www.saabrally.com/forums/viewtop ... f=2&t=3905
which seems to show the SAAB boys are also having to use Rolons!
However, I also found this:
http://www.skandix.de/en/spare-parts/en ... n/1007619/
where they say they sell their "own-label" part, although it might still be no better than the Rolon.
The land rover one has a slightly different profile.Has anyone taken a look at the S3 Landrover version?
Club members will be happy to know that we are looking into a source of good quality tensioners to hold as club stock.
- lazeruspete
if i remember i will take this number to stores at work and see if they know where they come from.
i work at JLR so you would have thought they would......
viewtopic.php?f=19&t=23031
Proud TDC Member!
Proud TDC Member!
