High torque starter motor
Paul Roberts
#1 Post by Paul Roberts »
Currently have a problem with the starter motor getting "cooked" when using the Sprint in competition and then refusing to start. It's fine when cold. I want to get a high torque starter. It seems some manufacturers list the starter for both a Sprint and a TR7 while others have separate part numbers. Can anyone advise a good supplier and the correct part number - don't want to get it to Australia and then fine it is wrong!
Many thanks
Paul Roberts
Perth Western Australia
dursley92
Re: High torque starter motor
#2 Post by dursley92 »
I am using this one in my TR7 fitted with a Sprint engine so hope that doesn't confuse things even more. Its a Powerlite RAC406. Seems to work pretty good but I did fit a wrap around heat shield because its close to the tubular exhaust manifold.
Russ Cooper
Dursley
UK
Tamworthbay
#3 Post by Tamworthbay »
I have used power lite on other cars and the quality is superb. They are British made and service is second to none. When I bought my last one I spoke to a very helpful guy called George Shackleton - a relative of the great explorer Ernest. I couldn't recommend them more highly.
GTS290N
#4 Post by GTS290N »
Tamworthbay wrote:I have used power lite on other cars and the quality is superb. They are British made and service is second to none. When I bought my last one I spoke to a very helpful guy called George Shackleton - a relative of the great explorer Ernest. I couldn't recommend them more highly.
It's personal experience like yours that is invaluable when choosing suppliers and parts. Thanks for sharing.
#5 Post by soe8m »
For what's it worth nowaday's my comment is that these starters are bugger. For a period of nine years i drove about 50.000km a year daily with a dolomite and had three fails of these within two years. I did want just as you more reliability but it was the opposite. The denso starters are very good but the problem is that when they are modified to the hi torque power blah suitable for Triumph the contacts and the coil are replaced by boogie woogie chinese repair parts and that causes the fails. As all parts it has to be as cheap as possible. I think when they leave the 20 year old original toyota relay on it and only fit the adapter plate and the gear wheel you have a better starter than what they make of it now. When you drive 300km a year with your dolomite it will be a perfect replacement but for daily or motorsport it is as unreliable or even worse than the original.
For many years i use and more in Holland a modified modern bosch starter what is a slightly modified new original bosch what does last normally for 30 years and 500.000km. I do not know the type but it is 1,7kw as to the original lucas of 0,7kw. A friend of min does work at a starter motor company so can compare and switch parts and he does make them for me. They are twice as expensive as the average high torque but do not fail.
Paul Roberts
#6 Post by Paul Roberts »
Thanks for the replies. Much appreciated.
Paul
Aye,....
#7 Post by sprint95m »
soe8m wrote:For what's it worth nowaday's my comment is that these starters are bugger. For a period of nine years i drove about 50.000km a year daily with a dolomite and had three fails of these within two years. I did want just as you more reliability but it was the opposite. The denso starters are very good but the problem is that when they are modified to the hi torque power blah suitable for Triumph the contacts and the coil are replaced by boogie woogie chinese repair parts and that causes the fails. As all parts it has to be as cheap as possible. I think when they leave the 20 year old original toyota relay on it and only fit the adapter plate and the gear wheel you have a better starter than what they make of it now. When you drive 300km a year with your dolomite it will be a perfect replacement but for daily or motorsport it is as unreliable or even worse than the original.
Thanks Jeroen,
that is very helpful to me.
I have been thinking about fitting a Hi-torque starter for a while now because I have had two reconditioned Lucas starters that only lasted for a short time.
Currently I am using a new old stock Lucas starter but before fitting it, took the precautions of wrapping the exhaust manifold and also fitting a Lucas solenoid heat shield.
S3George
#8 Post by S3George »
I'm looking a fitting on of these, I see only one small wire going to the solenoid, what happens to the one with the small spade connector?
#9 Post by soe8m »
You fit them both to the high torque starter spade terminal and remove the white yellow from the ignition coil. The white yellow has to activate a relay now what is going to deliver the bypass high start voltage for your ignition coil.
S3George
#10 Post by S3George »
Thanks for that, do I need to connect a relay up next to the coil
Could I fit an ordinary 12v coil with an ignition controlled feed
#11 Post by soe8m »
You can use any 12v relay. Ignition feed on 30. 87 to coil+, 86 to starter wire white/yellow and 85 ground.
S3George
#12 Post by S3George »
Thanks Jeroen, should be going tomorrow hopefully
GinettaG15
#13 Post by GinettaG15 »
soe8m wrote: Wed Mar 14, 2018 7:49 am You fit them both to the high torque starter spade terminal and remove the white yellow from the ignition coil. The white yellow has to activate a relay now what is going to deliver the bypass high start voltage for your ignition coil.
as i´m also middle within deciding what to do (new solenid for my orginal starter or high-torque starter) i need to ask again:
the high-torque is not a 100% direct replacemment in terms of the electric connections?
the connection for the 3rd wire going to the ignition-coil is not present at those high-torque ones?
what to do?
triumphdolomiteuk
Site Admin
Site Admin
#14 Post by triumphdolomiteuk »
https://www.powerlite-units.com/search. ... a=category
These guys will offer all the advice you need; we helped them develop the starter for the 1500 models.
gmsclassics
#15 Post by gmsclassics »
Hi Paul
I fitted a Roadrunner Hi Torq starter to my road car in Nov 2010. Since the it has covered about 25,000miles without issue. They happily fitted the extra terminal on the solenoid as that car still runs a ballast resistor circuit when starting. Fitting wasn't as easy as a standard but using cap screws helped. Note they still use the three mounting holes. Roadrunner are based in Tauranga, NZ but don't know if they have an agent in your part of the world. https://www.roadrunner-starters.com/col ... sh_triumph. They still list the Sprint model RS205D.
However, for all of the 100+ race meetings I ran my Maple Sprint in NZ, I never found the need to switch from a standard starter.
I was conscious that under bonnet heat was of concern so I ran an aluminum tray between the spoiler and the subframe, had extra air inlet holes in the front and for the most part ran without the two inner headlamps. That certainly helped with increasing airflow past the engine. I also had the 12" electric radiator fan wired in with manual override to avoid underbonnet temperature rise after stopping in the pits. The EWP115 was the last extra I fitted - superb kit.
photo 1.JPG (109.58 KiB) Viewed 15268 times
