#601 Post by Jon Tilson »
I wouldnt worry....mine was orange out of the box...
Dont pay much attention being a non smoker but I cant recall ever seeing a green one...
#602 Post by Mad Mart »
Mahesh wrote:Have to obtain a green ring to match the dials, seems unlikely.
I may have to order an Ebay unit with a green ring and diy (bodge) it.
No green rings were ever fitted. That's always been one of my gripes.
Mahesh
#603 Post by Mahesh »
Rained yesterday evening, but no water inside the car on this occasion, the last grommet may have done the trick.
Took the tunnell out for a clean and paint up, but the padding is a bit worn (more aged than worn)
are they any suppliers for this, or should I "stick with it" and just glue it down ?
I have plenty of sound deadening material but it is thinner with a aluminum top and bitumen backing.
#604 Post by Jon Tilson »
I'd take the padding off and get rid of the rusty corner and then stick it back on. I'm not sure what glue to recommend though as Evostick
now haas a different formula to the stuff they used back then which could last 40 years in the right places...
Flyfisherman
#605 Post by Flyfisherman »
There is somebody on ebay thats does a soundproofing felt kit for dolomite, I thinks its about £30.00. I re did mine using a large off cut of carpet underlay its about 1/2" thick, all trimmed nicely and stuck using instant contact glued it to the tunnel after I had the tunnel powder coated
Paul
Mahesh
#606 Post by Mahesh »
Thanks guys,
I've done some cleanup on the tunnel before reading your replies, the cordless drill however only managed half a job before the motor started squealing,
2016-05-23 20.31.50.jpg (210.9 KiB) Viewed 1325 times
2016-05-23 20.32.07.jpg (142.39 KiB) Viewed 1325 times
#607 Post by Carledo »
A lot of older Ford faglighters come with a green ring, try the scrappies!
Mahesh
#608 Post by Mahesh »
Getting there
2016-05-24 21.28.34.jpg (204.22 KiB) Viewed 1299 times
2016-05-24 21.29.25.jpg (143.44 KiB) Viewed 1299 times
Mahesh
#609 Post by Mahesh »
Removing the black from the bezel on the clock was a lot more work than I thought it would be,
also the plastic window is easy to damage, and then a pain to cut a piece in glass, adjustment
knob just about works.
Putting the bezel back is not too bad, but having to roll the clock against metal to flatten the
bezel rear lip down is worrying.
Best I could do, (and never want to do another, rather remove and replace water pump daily)
2016-05-25 15 27 08.jpg (83.67 KiB) Viewed 1282 times
I do have a Kienzle labeled version, but the seconds hand movement is different to this clock, which
moves once a second, as opposed to three times a second.
Mahesh
#610 Post by Mahesh »
More tunnel cleaning,
2016-05-25 21.26.59.jpg (155.09 KiB) Viewed 1258 times
The way it's cleaning up, I may just lacquer instead of paint, shame it won't be seen.
GTS290N
#611 Post by GTS290N »
I do like a nice clean tunnel. :D
Mahesh
#612 Post by Mahesh »
I could easily clean and polish up to a mirror finish,
but what's the point, will paint the underside and leave the top.
2016-05-26 21.40.14.jpg (154.45 KiB) Viewed 1227 times
GTS290N
#613 Post by GTS290N »
I'd paint the top as well - be a shame to go to all that effort and have rust return after a few years. Go for a really ridiculous colour. It'll be covered by carpet for decades and imagine the shock when it's finally stripped back :lol:
Mahesh
#614 Post by Mahesh »
I'd swear it's aluminium or an alloy, all the rust on it was trickled down from the body shell, there is no through rust.
#615 Post by Jon Tilson »
Try a magnet on it...
I doubt its alloy...and I have had them rust right through....
