They are definitely steel, I had to do some welded mods on the Carledo to clear the exhaust and alter the gear lever position.
Checked this morning, it is steel, just can't believe how light it is, and even with all the surface rust
not a single hole through.
How about Inca with stonechip underneath? You could make an inspection hatch for easy access to the clutch slave cylinder.
- Flyfisherman
Nice, is that a foam or rubber seal ?
- Flyfisherman
NeopreneMahesh wrote:Nice, is that a foam or rubber seal ?
Paul
While the tunnel is out might as well put a new speedo cable in, does anyone know how many teeth the pinion drive gear has? and it seems I don't have an angle drive
Sprints don't have an angle drive.
Thanks, that's me looking at parts without double checking applicable models.
An annoyance from day one, sorted
I just bought a GSD293 from RB for £11, and it fitted perfectly on the OD box. Previous owner had routed the old cable above the crossmember which seems to be too tight an angle, so I've found a clip that goes in the small hole in the end of the crossmember that holds the cable nicely and maintains a smooth radius. Nothing listed on the parts pages for that clip, but it is a very convenient hole and directly in line with the cable.
So where did you get the green ring from for your cigarette lighter Mahesh?Mahesh wrote:An annoyance from day one, sorted
Ebay,
Steve recommend to look at old Ford's, this one is from a Capri.
3 mins in the ultrasonic, and it came out like new.
Someone had to do it,
