So I got the parcel shelf out to replace the front padding part.
The little metal split pin/ studs are fun should I re use them or find new ones?
If new ones does anyone know where from, I've looked at previous threads etc but no joy.
Secondly what's the best way to clean up the actual shelf itself?
My parcel shelf was quite worn and scuffed. I used black shoe polish - the lazy liquid stuff in a bottle with a sponge applicator. Apply liberally and wipe/ polish off after few minutes. It certainly improved the appearance.
I suppose if you have the shelf out you could try spraying the fibreboard with a flexible vinyl paint.
Sico40 wrote:So I got the parcel shelf out to replace the front padding part.
I found that the clips are best released from inside the boot, just push together then push up.
