1973 Sprint body / commission number plate info
simonhorton
#1 Post by simonhorton »
Hi All,
I'm just doing a bit of research for early Sprints built in 1973
Please can people put there cars commission / body number on here , as trying to find any numbers that are close to my car
VA 62 DL
80495 WB
Many thanks
Simon
OBJ
Re: 1973 Sprint body / commission number plate info
#2 Post by OBJ »
Hi Simon,
Here's mine.
Simon
SprintMWU773V
TDC Staffs Area Organiser
#3 Post by SprintMWU773V »
You might also like to know that the body number of my shell is 068684 WO. This shell was made towards the end of production but was never allocated to a build and hence it never had a chassis number. Unfortunately I forgot to remove the body number tag when it was sent to SPL and it has been lost. I still have the one for my original car somewhere.
#4 Post by Toledo Man »
Mike, you forgot VA6 which now belongs to Paul & Polly B. Maybe they can provide you with the body number. VA16 will have ended up in the posession of the late Brian Kitley's estate (following his death) and may have been disposed of.
simonhorton
#5 Post by simonhorton »
Hi All ,
My car is VA 62 DL
Commission / body number 80495 WB
Built in March 1973
Simon
simonhorton
#6 Post by simonhorton »
Here's a pic of the plates on my car
Simon
Steve28
#7 Post by Steve28 »
Hi there, mine is VA 473 body number 85986 WB
1973 yellow Sprint L reg
1979 1500 SE T reg
1979 1500 SE V reg
1980 vermillion 1500hl W reg
1975 green 1500tc auto P reg
1973 Brown Toledo 2 dr L reg
1973 Green Toledo 2 dr L reg
1983 White Toyota Tercel 4x4
1987 Brown Toyota Tercel 4x4
1988 Blue Toyota Tercel 4x4
1999 Toyota Corolla vvti est
2005 Ford ranger thunder XLT
PollyB
#8 Post by PollyB »
Hi Guys,
VA6's body number is 67803WB. This makes the body older than VA1's but Triumph always were a bit random.
It isn't Orange!!!!!!
#9 Post by xvivalve »
Paul Geering's car is VA124 if memory serves me correctly. I owned VA122 about 15 years ago, but don't have record of the body number unfortunately. Last I heard it was owned by a Mr Ivens of Staffordshire, laid up with a blown engine and a rotten front end.
soggy
#10 Post by soggy »
I still own VA122 and it has just come out of storage to be recommissioned. The body number quoted from the heritage cert is T.83635/WB Its original engine was VA/65-HE though i think this is not the original one that came in the car when I got it back in 1999. I have a good running engine that came from a terminally rusty late W reg Sprint that will be used in its recommissioning. I have stored it full of almost neat antifreeze so hope it has not corroded inside over the last decade or so!
The build date is quoted as 13th march 1973 and was obviously ordered for the 1st August M plate as that was when it was registered.
It is about time i got it working again especially as it is now free road tax and will probably become mot exempt in the next couple of years
