Today I finally got round to refurbishing my alloys. First I pressure washed them which removed most of the paint off them. As I've gone for a painted finish I got all corrosion and loose paint off with a knot wheel. It cleaned them up nice and made a key for the paint. Wouldn't use it if you want a bare metal finish though. I then put a couple of coats of grey primer on and then a good coating of top coat. Once that was dry I painted the black inserts using hamerite. Took a while with a small brush.havnt fitted them on the car yet as I wanted to let the paint set properly before I fitted tyres. Will get pics of them on the car when I've fitted them.
- Wheels after pressure washing
- IMG_20161210_213221.jpg (153.38 KiB) Viewed 41604 times
- Cleaned up with the knot wheel
- IMG_20161210_213256.jpg (109.8 KiB) Viewed 41604 times
- Grey primer
- IMG_20161210_213326.jpg (107.51 KiB) Viewed 41604 times
- A before, primer and top coat pic
- IMG_20161210_213424.jpg (129.08 KiB) Viewed 41604 times
- One wheel done
- IMG_20161210_213455.jpg (172.31 KiB) Viewed 41604 times
- Set of four wheel and centre caps done
- IMG_20161210_213529.jpg (152.87 KiB) Viewed 41604 times
Havnt been on here for a while but been sorting out the front end. I'm sure everyone knows the process so I'm going to upload all the pics of my progress. There's quite a few so it going to take a while!
- IMG_20170416_173329.jpg (152.89 KiB) Viewed 41478 times
- IMG_20170416_173251.jpg (149.82 KiB) Viewed 41478 times
- IMG_20170416_173211.jpg (144.88 KiB) Viewed 41478 times
- IMG_20170416_173130.jpg (149.84 KiB) Viewed 41478 times
- IMG_20170416_173055.jpg (162.43 KiB) Viewed 41478 times
- IMG_20170416_173019.jpg (166.23 KiB) Viewed 41478 times
- IMG_20170416_172934.jpg (189.12 KiB) Viewed 41478 times
- IMG_20170416_172905.jpg (148.23 KiB) Viewed 41478 times
- IMG_20170416_172817.jpg (167.45 KiB) Viewed 41478 times
- IMG_20170416_172720.jpg (165.95 KiB) Viewed 41478 times
More pics
- IMG_20170416_174114.jpg (141.42 KiB) Viewed 41477 times
- IMG_20170416_174150.jpg (144.73 KiB) Viewed 41477 times
- IMG_20170416_174227.jpg (146.14 KiB) Viewed 41477 times
- IMG_20170416_174305.jpg (125.76 KiB) Viewed 41477 times
- IMG_20170416_174343.jpg (161.39 KiB) Viewed 41477 times
- IMG_20170416_174425.jpg (132.43 KiB) Viewed 41477 times
- IMG_20170416_174610.jpg (140.83 KiB) Viewed 41477 times
- IMG_20170416_174639.jpg (123.45 KiB) Viewed 41477 times
- IMG_20170416_174717.jpg (133.16 KiB) Viewed 41477 times
- IMG_20170416_174750.jpg (125.23 KiB) Viewed 41477 times
More pics
- IMG_20170416_175107.jpg (147.29 KiB) Viewed 41476 times
- IMG_20170416_175147.jpg (140.5 KiB) Viewed 41476 times
- IMG_20170416_175229.jpg (150.27 KiB) Viewed 41476 times
- IMG_20170416_175310.jpg (151.59 KiB) Viewed 41476 times
- IMG_20170416_175349.jpg (185.81 KiB) Viewed 41476 times
- IMG_20170416_175423.jpg (156.7 KiB) Viewed 41476 times
- IMG_20170416_175450.jpg (154.06 KiB) Viewed 41476 times
- IMG_20170416_175523.jpg (141.78 KiB) Viewed 41476 times
- IMG_20170416_175552.jpg (166.93 KiB) Viewed 41476 times
- IMG_20170416_175627.jpg (133.76 KiB) Viewed 41476 times
A couple more till I resize the next lot from today
- IMG_20170416_180018.jpg (146.75 KiB) Viewed 41476 times
- IMG_20170416_180054.jpg (155.7 KiB) Viewed 41476 times
Pics from today's work
- IMG_20170416_185122.jpg (181.12 KiB) Viewed 41475 times
- IMG_20170416_185154.jpg (164.49 KiB) Viewed 41475 times
- IMG_20170416_185231.jpg (186.03 KiB) Viewed 41475 times
- IMG_20170416_185257.jpg (154.93 KiB) Viewed 41475 times
- IMG_20170416_185332.jpg (136.17 KiB) Viewed 41475 times
- IMG_20170416_185407.jpg (147.58 KiB) Viewed 41475 times
- IMG_20170416_185431.jpg (206.14 KiB) Viewed 41475 times
- IMG_20170416_185510.jpg (161.13 KiB) Viewed 41475 times
- IMG_20170416_185551.jpg (208.11 KiB) Viewed 41475 times
- IMG_20170416_185630.jpg (232.25 KiB) Viewed 41475 times
Most of inner valance finished. Part of out valance put back on. Nutserts fitted to attach grill. Bumper brackets cleaned up and new bolts fitted
- IMG_20170416_190051.jpg (182.22 KiB) Viewed 41475 times
- IMG_20170416_190151.jpg (168.23 KiB) Viewed 41475 times
- IMG_20170416_190225.jpg (196.54 KiB) Viewed 41475 times
- IMG_20170416_190258.jpg (217.95 KiB) Viewed 41475 times
- IMG_20170416_190326.jpg (201.42 KiB) Viewed 41475 times
- IMG_20170416_190358.jpg (177.47 KiB) Viewed 41475 times
- IMG_20170416_190433.jpg (196.5 KiB) Viewed 41475 times
- IMG_20170416_190504.jpg (185.36 KiB) Viewed 41475 times
- IMG_20170416_190533.jpg (213.31 KiB) Viewed 41475 times
- IMG_20170416_190600.jpg (157.16 KiB) Viewed 41475 times
Good work there Phil, should be a nice solid front end when youre finished
Nice fabrication work there. Clearer on here than the f-b posts too.
That's looking great Phil, I think your's was a tad worse than mine but it's nice to see someone else doing the same job as me and the way they deal with the fab work. I do like the way you've done the filler sections between the inner and outer valence under the lights, it looks much better than my folded versions.
I also like the way you've done the outer upper valence, I'm going to copy you I think that way I'll keep the welding away from the GRP eyebrows I'm using.
No one wants burnt eyebrows, James!
They are the same pics so I don't know why they are better on here.Jon Tilson wrote:Nice fabrication work there. Clearer on here than the f-b posts too.
It makes it easier to line the panels and weld. I also put the cutting disc I used in the gap when I tacked the panel together.James467 wrote:That's looking great Phil, I think your's was a tad worse than mine but it's nice to see someone else doing the same job as me and the way they deal with the fab work. I do like the way you've done the filler sections between the inner and outer valence under the lights, it looks much better than my folded versions.
Everything looks better on the forum page.philgroom wrote:They are the same pics so I don't know why they are better on here.Jon Tilson wrote:Nice fabrication work there. Clearer on here than the f-b posts too.
Havnt added any progress photos for a while so I'm going to start getting it back up to date.
- IMG_20170703_195526.jpg (110.15 KiB) Viewed 41202 times
- IMG_20170703_195602.jpg (101.84 KiB) Viewed 41202 times
- IMG_20170703_195638.jpg (129.48 KiB) Viewed 41202 times
- IMG_20170703_195708.jpg (124.3 KiB) Viewed 41202 times
- IMG_20170703_195738.jpg (128.36 KiB) Viewed 41202 times
- IMG_20170703_195805.jpg (130.7 KiB) Viewed 41202 times
- IMG_20170703_195836.jpg (106.71 KiB) Viewed 41202 times
- IMG_20170703_195906.jpg (148.09 KiB) Viewed 41202 times
- IMG_20170703_195935.jpg (139.91 KiB) Viewed 41202 times
- IMG_20170703_200008.jpg (121.59 KiB) Viewed 41202 times
