door mirrors
wellskint
door mirrors
#1 Post by wellskint »
my 1500 only has the factory fitted interior rear view mirror and i was thinking of getting a nice pair of chrome door mirrors from rimmers. is it a big job to pit them/drill the door holes
marko
Re: door mirrors
#2 Post by marko »
They usually "pit" by themselves after a few years!😁 Not a big job to fit, just put some primer or hammerite in the holes after drilling them else they'll eventually rust.
Bumpa
Re: door mirrors
#3 Post by Bumpa »
I've just fitted a pair on my 1850. They are supposed to use a plastic expanding fitting that can be used from the outside only. I couldn't make them firm enough like that and they wobbled about all the time. Eventually I used screws and nuts inside the door. A bit of a fiddle but it worked.
Re: door mirrors
#4 Post by Toledo Man »
I used spire clips with the self tapping screws to secure mine. I've still got my passenger mirror to fit so I'll have to document it on video and with some photos.
wellskint
Re: door mirrors
#5 Post by wellskint »
thanks guys . is there a specific place (in measurements i.e x cm from fwd edge of door etc) that i should fit them at
Re: door mirrors
#6 Post by Carledo »
There seems to be a general discrepancy over where to fit the door mirrors, insofar as the ideal spot on the drivers side is nowhere near ideal on the passenger side - like all you can see is the 1/4 light frame! I've got some original doors here, i'll do some measuring later and report back!
wellskint
Re: door mirrors
#7 Post by wellskint »
hi all was anyone ever able to get the measurements for where exactly they should be sat? thanks
Bumpa
Re: door mirrors
#8 Post by Bumpa »
I just put them as forward as they could go without fouling the opening of the quarter light.
Door Mirror.jpg (38.68 KiB) Viewed 1490 times
Bish
Re: door mirrors
#9 Post by Bish »
Bumpa wrote: Sat Oct 20, 2018 12:05 pm I just put them as forward as they could go without fouling the opening of the quarter light.
That’s sound advice right there. My car only has a drivers door mirror that’s fitted in a position which doesn’t allow for the quarter light to open fully. Very annoying. I suppose the mirror was factory fitted, so points to another of BLs design flaws?
dollyman
Re: door mirrors
#10 Post by dollyman »
Bish wrote: Sat Oct 20, 2018 1:03 pm
That sounds about right..... Mine were both factory fitted and n/s one fouls the quarter light :(
