It is currently Tue Apr 16, 2024 4:53 pm
PostPosted: Tue Jan 29, 2019 1:01 am
Hi,
Having a real strong dislike for sighting modern plastic electrical ties under the hoods (or anywhere) on veteran & vintage cars, recently I bought several of these (8 inches long X 1/4 inch wide) brass ties from the "Restoration Supply Company", and their spiel is.... "Authentic lightweight brass wire tie to correctly “tie stuff” together on vintage vehicles".
My question is....What is the 'correct" way to tie them off?
The pointy end from the outside through the end slot/hole and then upwards and outwards through the innermost hole? .....seems like one way that'd work, but I just don't know. This is in order to secure some exposed wiring loom on my 1915 speedster and because it'll be clearly visible, I want to get it right.
Anybody "in the know"?
Thanks & Cheers,
Rob
"When everything seems to be going against you, remember that the airplane takes off against the wind, not with it". HENRY FORD
1915 Ford "T" Speedster (Evangeline), 1921 Ford "T" Tourer (Anastasia), 1955 Zephyr 6 (Purdey), 1975 Dolomite SPRINT (Daisy), & a couple of moderns.
PostPosted: Tue Jan 29, 2019 8:32 am
I think through the nearest hole first then back through to the furthest hole with a bend so the double bend stops it undoing. Hard to explain lol
PostPosted: Tue Jan 29, 2019 9:08 am
Sounds logical to me Tony.
Good advice from you as usual.
Cheers,
Rob
PostPosted: Tue Jan 29, 2019 6:31 pm
They are called Buckle clips through the inner most hole first , pull tight, then through the outer hole and bend back but these are 'too old' for Dolomites why not use the original type or binding tape?
PostPosted: Tue Jan 29, 2019 6:37 pm
Because they're for his Speedster! :wink:
1997 TVR Chimaera 450
PostPosted: Tue Jan 29, 2019 6:41 pm
Oh ok ;)
PostPosted: Tue Jan 29, 2019 7:24 pm
Thanks Gents,
I appreciate your good advice.
Cheers,
Rob
Users browsing this forum: DotBot [Bot] and 6 guests
