It is currently Sat Apr 20, 2024 3:53 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Sun Feb 10, 2019 12:40 pm
Can either of you post a photo of the C-posts in Hammerite please? Did you both use the hammered finish? The vinyl on mine isn't bad, but there are signs of it coming away at the top edge.
PostPosted: Mon Feb 18, 2019 12:11 pm
I got the time to have a look at the wet floor issue yesterday. I stripped back the sound deadening material from the bulkhead and found that although there is surface rust, there are no holes or weakened metal, so I'm pleased about that. Having looked carefully at where the water appears in the car I am 99% sure it gets in round the clutch master cylinder which I replaced last year. There is an air box drain right above it which makes sense to me.
So after cleaning up the rust and treating it I intend to fit a thin gasket with sealant between the clutch cylinder and the bulkhead and I hope that will sort it. We shall see!
PostPosted: Mon Feb 18, 2019 2:10 pm
As requested I will attach a photo of the painted C panel.
PostPosted: Mon Feb 18, 2019 4:01 pm
They're 'D' posts. :wink:
1997 TVR Chimaera 450
PostPosted: Tue Feb 19, 2019 8:53 am
Thanks for the picture Richard. The paint doesn't look at all out of place, and a lot better than scruffy vinyl. Mart, if the rear pillar is the D-post, where is the C-post? I would say the screen pillar is A, the door pillar is B and the rear pillar is C. The quarter light supports surely don't count?
PostPosted: Tue Feb 19, 2019 9:55 am
Front door hinges on the 'A' post.
Front door latches on the 'B' post.
Rear door hinges on the 'C' post.
Rear door latches on the 'D' post.
Can't remember where I got this from...Alun? :shrug:
PostPosted: Tue Feb 19, 2019 1:56 pm
But under your scheme the B and C posts are the same thing. I shall continue to call them A, B and C. You need a stretch limo with three doors on each side to have a D post! :D
PostPosted: Tue Feb 19, 2019 4:26 pm
Bumba, I concur with your analysis. :D
According to your analysis the 'B' post and 'C' post are one and the same structure.
My 1973 VW "1600" Type 2 campervan has "A", "B", "C" & "D" pillars. The pre-1968 split-screen VW Type 2s have even more! :shock:
Having only a circa 1978-vintage, Olympus OM2 SLR camera with 35 mm colour-reversal film for taking pictures, I won't be in a position to provide any pictures of my hammered-finish, black Hammerite painted roof and C-pillars for the foreseeable future.
The advantage of the hammered-finish is that it effectively camouflages all manner of underlying imperfections. I also later used this paint for the lower vehicle sides up to the lower swage lines and around the front wheel arches, which also mutes the large expanse of Mimosa-yellow paintwork.
Regards.
Nigel A. Skeet
PostPosted: Tue Feb 19, 2019 5:51 pm
Or an estate car/station wagon!
PS The C pillars are only called D pillars on a Dolomite because they have a big D written on them! :lol:
PostPosted: Tue Feb 19, 2019 6:48 pm
So does a Sprint have a 'Sprint' post? :lol:
PostPosted: Tue Feb 19, 2019 10:30 pm
Mart, you're such a wit! :lol: :lol: :lol: :lol: :lol:
Users browsing this forum: Google and 70 guests
