It is currently Tue Apr 16, 2024 9:19 pm
 Post subject: Door check strap pins
PostPosted: Sat Mar 09, 2019 6:46 pm
It seems that both the front door check strap pins have gone walkies while the paint was drying.
Anybody any idea where I might get a pair. Like, are they the same as 2000's?
PostPosted: Sat Mar 09, 2019 10:22 pm
Sorry don't know size but you can buy clevis pins on eBay
PostPosted: Sat Mar 09, 2019 10:37 pm
As a temp fix, a 7/16th nyloc nut and bolt will work :D
PostPosted: Sun Mar 10, 2019 9:31 am
Yes I have just replaced some rust old bolts with these
https://www.ebay.co.uk/itm/323714173870 ... 3714173870
1/4 dia X 5/8 long seems about right although the perfectionist might drill out elongated holes to a slightly bigger size.
PostPosted: Sun Mar 10, 2019 9:43 am
Yep. That's what I did!
PostPosted: Sun Mar 10, 2019 12:27 pm
The bolt nyloc and washers sounds good as a temp fix, but does anybody know if this https://rimmerbros.com/Item--i-613622FK will fit the dolomite's check straps?
PostPosted: Sun Mar 10, 2019 12:52 pm
Those are ones Graham :D I have to confess i left the nut and bolt in mine as they were stainless :wink:
PostPosted: Sun Mar 10, 2019 1:28 pm
Well I've ordered the nuts bolts and washers in stainless, as part of getting the bits to mount the front headlamp panels. So I'll fit those for now and see if I feel like getting the clevis pins later.
Thanks all.
PostPosted: Fri Mar 15, 2019 12:07 am
Original factory equipment was a rivet, normally completely or partially destroyed on removal!
Personally, i'm a fan of the 1/4" clevis pin and R clip (as used on brake pad pins) A neat and easy to remove solution!
PostPosted: Fri Mar 15, 2019 4:05 pm
https://robsport.co.uk/index.php/online ... door-rivet
Users browsing this forum: No registered users and 16 guests
