It is currently Tue Apr 16, 2024 9:55 pm
 Post subject: Subframe Puzzler
PostPosted: Sat Jun 08, 2019 1:46 pm
What model is this off then?
It doesn’t look to have been modified...
 Post subject: Re: Subframe Puzzler
PostPosted: Sat Jun 08, 2019 3:35 pm
Looks like my 1500 subframe, unless I'm missing something?
PostPosted: Sat Jun 08, 2019 4:01 pm
1500 auto :bluewave:
PostPosted: Sat Jun 08, 2019 5:25 pm
Since when have 1500s had twin bolted mounts at the front of the engine?
PostPosted: Sat Jun 08, 2019 5:37 pm
Same shape mount as the 1850, two bolts to the subframe, one to the donk.
PostPosted: Sat Jun 08, 2019 5:54 pm
Could have sworn they were single bolt, both sides...must be age catching up with me...or the drugs...or both!
PostPosted: Sat Jun 08, 2019 5:56 pm
Question is then, where did I get it from??? I've had it sitting in my yard since goodness knows when on the misapprehension it was Sprint!
Anyone need a 1500 subframe?
PostPosted: Sat Jun 08, 2019 7:34 pm
Its only for the 1500 Auto, the subframe for a 1500 manual as the extra A shape at the rear to take the gearbox mount doesn't it?
PostPosted: Sat Jun 08, 2019 9:34 pm
Only just seen this, Jod and Julian are perfectly correct, it's a 1500 Auto subframe and unique to that model. I have one just like it lying around in my yard from the white car I broke last year. I'd not seen one before that turned up either! I'll take it off your hands if you like, it's one I can safely cut about for my Vauxhall conversions and it'll never be missed by someone needing a slant frame.
PostPosted: Sat Jun 08, 2019 9:39 pm
Site Admin
Site Admin
Yes it does, quite right.
PostPosted: Sun Jun 09, 2019 7:19 am
Also suitable for 1500 O/D, even though they usually have the triangular extension which isn't actually needed with the overdrive gearbox.
PostPosted: Sun Jun 09, 2019 10:38 am
I would take it as a spare if nearer or if i get down that way some time soon.
1973 yellow Sprint L reg
1979 1500 SE T reg
1979 1500 SE V reg
1980 vermillion 1500hl W reg
1975 green 1500tc auto P reg
1973 Brown Toledo 2 dr L reg
1973 Green Toledo 2 dr L reg
1983 White Toyota Tercel 4x4
1987 Brown Toyota Tercel 4x4
1988 Blue Toyota Tercel 4x4
1999 Toyota Corolla vvti est
2005 Ford ranger thunder XLT
Users browsing this forum: cliftyhanger, Google and 12 guests
